front end compatibility
Old Mar 24, 2019 | 09:33 PM
Kramercd's Avatar
Kramercd
Thinking about swapping the front end from the donor truck(85 f150) to my 82 f100. Just looking at it it seems doable. Haven't measured yet, just an idea rolling around while I'm getting some painting done. The 85 appears to be forged while the 82 is thinner tubing
I'm thinking it should be fairly straightforward since I'm swapping everything in whole, assuming the measurements are close.
Old Mar 25, 2019 | 07:47 AM
FuzzFace2's Avatar
FuzzFace2
Dose the 82 have kingpins?
Do both trucks have power brakes?
I ask because kingpin trucks have 2 wheel bolt pattern so check the 2 trucks.
Other wise I believe it will bolt in and that is what you have to do if you want to use drop beams because they are not made for our trucks with kingpins.
Dave - - - -
Old Mar 25, 2019 | 07:55 AM
Kramercd's Avatar
Kramercd
Off hand I'm going to tell you no on the king pin, and yes on the power brakes, but I'm going to try and set aside some time today to compare the two trucks.
Old Mar 25, 2019 | 08:09 AM
FuzzFace2's Avatar
FuzzFace2
I think the big thing is wheel bolt pattern.
I know it was on my 81's with kingpins but 1 was power the other non power brakes.
Dave - - - -
FuzzFace2
Feb 6, 2016 09:28 AM
DWV88
Jun 24, 2010 09:12 PM
docholiday72tx
21
Jun 7, 2010 09:23 AM
sinchicken
Feb 14, 2005 06:17 PM
bigern6697
Aug 31, 2003 12:00 AM
