Corrosion on trailer plug?
Old Mar 21, 2019 | 11:20 PM
Faceplant409's Avatar
Faceplant409
Anyone ever had a bad connection due to a corroded 7pin trailer plug?
Today I hooked up to my dump trailer with electric brakes and when I tested the brakes by pinching the buttons below the dash, the truck said no trailer connected....
After resetting the 7 pin several times it seemed to get work.
I think I’ll clean the plug tabs and add some dilectric grease.
Thoughts?
Old Mar 22, 2019 | 10:19 AM
wrvond's Avatar
wrvond
Very common. Check the wiring on the back side as well.
Old Mar 22, 2019 | 02:06 PM
dustin cri's Avatar
dustin cri
yes had mine replaced was burning fuses like crazy. would stop me from locking my doors kinda wierd
Old Mar 22, 2019 | 02:27 PM
PentaPop's Avatar
PentaPop
The back side of mine got packed with dielectric grease the day it came home because it seemed like a common topic here on FTE. It’s super easy to unplug and inspect/add grease!
Old Mar 23, 2019 | 05:36 AM
Chrislorl6211's Avatar
Chrislorl6211
Agreed, you have to keep it clean (that includes the trailer side) and coat the connections in Dielectric grease. You can get it at any auto parts store. If they look at you funny ask for "spark plug grease". Buy the tube not the little packets and do every plug you can under the truck. A little goes a long way.
On the trailer side keep the plug off the ground and out of the dirt. I don't know how many I see laying on the ground next to a trailer. I put a sandwich bag over mine when not in use. This keeps blowing dust from building up on the contacts and sticking to the grease.
Old Mar 23, 2019 | 10:31 AM
Faceplant409
Thanks for the replies.
I did remove the 7 pin at the bumper and pack it a few months ago. The odd thing is I don’t think I’d towed anything since and was hoping I hadn’t screwed something up in the process...
Ill clean up the trailer plug.
The sandwich bag is a great idea. (Till it fills with water...) lol.
Old Mar 23, 2019 | 11:17 AM
acelefty's Avatar
acelefty
I got one of these for my 5'er and it works great for keeping the plug off the ground and clean. Probably the best $10 I have spent on that trailer. 7 Way Plug Guard
Old Apr 14, 2019 | 05:33 PM
dd5149's Avatar
dd5149
Does the back side of the 7 pin just unplug or is there a tab to remove?
Old Apr 15, 2019 | 08:12 AM
jrd4849's Avatar
jrd4849
There is a tab on the plug that you have to push in to release the latch then just unplug it while holding the tab in.
DirtRacer96m
Aug 19, 2018 08:18 AM
Tflynn
Dec 23, 2017 09:00 AM
oldrifleman
2009 - 2014 F150
Apr 28, 2015 12:17 AM
Bob Landry
Oct 27, 2013 07:20 PM
loganworks
All Things Towing
Apr 15, 2011 12:35 PM
