64 Generator Wiring
Old Mar 21, 2019 | 12:53 PM
Mearntain's Avatar
Mearntain
64 Generator Wiring
64 F100 223 w/ generator
I've got a loose wire with a ring terminal hanging out of the harness going to the generator on my truck. Between the Truck Shop Manual and Truck Parts Catalog, I cant find any drawings or references to where the wires should go. Where does the loose wire connect to? I've got an idea but not completely sure and dont want to make the wrong call. Thanks.
Old Mar 26, 2019 | 08:14 PM
Mearntain's Avatar
Mearntain
Just thought I'd bump this to see if anyone had any input on this.
Old Mar 26, 2019 | 09:22 PM
Sean Solo's Avatar
Sean Solo
So I've been doing some research on my generator as well. For me the best route to go is to bite the bullet and buy the 110 dollar aluminum mounting bracket with an alternator. Much more cost effective than the old generators and autozone has a lifetime warranty on them so buy it once and don't worry about it. Expensive up front for peace of mind down the road.
Old Mar 27, 2019 | 04:08 AM
Mearntain's Avatar
Mearntain
That's something I may consider, I'll do some looking into it. I was originally planning on doing a full restoration back to everything stock, but may be willing to budge on a couple things. Then again, even though I did just completely rebuild all 4 brake drums, I was considering switching to discs down the road so I guess an alternator wouldn't be that big of a jump in comparison.
Old Mar 27, 2019 | 07:43 PM
Kansafornia's Avatar
Kansafornia
Hard to tell from the pic (colors aren't obvious). Could it be a line to the voltage regulator assembly?
My '63 F250 had 2 lines to the VR - and one ground.
Below is NOT an OE image, but... Wiring Wizard shows the following for the '64 223:
Hope that helps.
Old Mar 27, 2019 | 07:59 PM
Mearntain's Avatar
Mearntain
Hope that helps.
That's perfect and should help alot! I'll get back out there tomorrow and check it out again. Just came in for the evening. Thanks
Old Mar 27, 2019 | 11:08 PM
Tedster9's Avatar
Tedster9
Generators are easy to repair and maintain, though not nearly as trouble free as an alternator. They do require periodic cleaning of the voltage regulator vibrating contacts. Nobody does this, and they will roast when the cutout relay sticks. This is a certainty without preventive maintenance.
For me it's partly aesthetics and partly stubborness. If the power plant was supplied with a generator an alternator just doesn't look right. This is especially true with a Flathead. So it's just kind of fun to make it work. It worked for them back then, I can make it work for me today. Always couple a rebuilt generator with a good used or NOS Autolite regulator. They have to be run in together and the voltage and current checked out. I'd say they are damn reliable when setup right. If the truck isn't a daily driver it should be about as permanent as an alternator.
If running a generator and external point regulator system we need to have a set of spoon or riffler files on hand. It's tricky, just running a fingernail file will likely ruin the points. It will get you back on the road, so there's that. A crisp dollar bill soaked in non-residue solvent dragged through the regulator contacts keeps them happy too, though sooner or later the crud will need cut with a file. Brushes will sometimes stick in the spring holders. I'm not anti-alternator, just that the OEM equipment can be made to work and there is a learning curve involved with old school, obsolete systems.
Old Mar 28, 2019 | 03:55 AM
Mearntain's Avatar
Mearntain
When I first started working on the truck, I noticed the previous owner had electrical tape wrapped around the vent holes on the back side of the generator. Would this have been there for any sort of functional reason? Or did the previous owner just possibly put that there for storage purposes?
Old Mar 28, 2019 | 01:16 PM
Tedster9's Avatar
Tedster9
Probably trying to keep road spray and grime out of the innards. Ford had a rubber boot to cover that area. Reproductions available. When they moved generators from up top to the side, that caused some problems.
Get yourself an extra backing plate, the brushes are pre-loaded and it pops on and off with two screws, takes about 5 minutes. The brushes have to conform to the commutator curve, also they will sometimes stick in the holders as they wear, carefully jamming them tight against the rotating generator will get charging going again.
New brushes have to be sanded at installation. See pic.
Old Apr 1, 2019 | 12:51 PM
Mearntain's Avatar
Mearntain
Great info! Thanks for that. Somehow I never got a notification of a new reply and just saw this now. Is there anywhere youd reccomend to get the rubber boot at?
Old Apr 1, 2019 | 03:19 PM
Tedster9's Avatar
Tedster9
I don't know who makes the boots, but lots of people sell them. Mac's, Dennis Carpenter, etc. They are kind of spendy for what they are. Keep fresh tight brushes, just a few swipes with a garnet paper will hollow out the faces so they conform closely to the commutator shape. This is a picture of cleaning a commutator. The brushes are sanded in a similar way, kinda have to figure out a way to sand them with a long strip of sandpaper. If this isn't done the new brushes will burn in just a few hundred miles. It only takes a few
seconds. Then keep the voltage regulator serviced once in a while and they are a pretty trouble free system.
Old Apr 1, 2019 | 06:44 PM
Mearntain's Avatar
Mearntain
Perfect, thanks alot. I'm definitely going to do that, especially since I got the truck after it sat in a garage for the past 30 some years, so I'm sure it needs it.
dwhawkins89
24
Jul 21, 2017 10:58 PM
flowney
Aug 11, 2016 12:30 PM
black58
May 10, 2011 07:28 AM
pntrbl
Jan 24, 2004 08:15 PM
72SportCustomRed
Electrical Systems/Wiring
Sep 9, 2003 09:23 PM
