Good afternoon, long time lurker on the forum just never signed up. A lot of good info here, but Im unable to find issues exactly like mine. My truck is an 18 6.7 4x4. I have an icon 2.5" level installed, a ready lift track bad relocation bracket, Carli 2 degree caster shims, and the fox ats steering stabilizer. On order now are some Carli front sway bar drop brackets. Truck sits on k02 35x12.5x18 on method wheels
After all. this, and taking what I thought are necessary measures to eliminate bump steer, the truck still bump steers lik crazy. I can let go for the wheel and it gets a mind of its own. I have had it aligned 4x at three different places. My next step would be to install an adjustable track bar bracket, but am unsure if it will work with the relocation bracket. Any help is appreiated.
I'm pondering the same option as I still have bump steer. I'm actually waiting on my sway bar drop brackets to see if that makes any difference what so ever. I've previously installed radius arm drop brackets and have had the castor adjusted numerous times to as high as 8+ degrees to try and resolve a bunch of steering issues to no avail. Took the brackets off and aired the tires back up to 60 psi and it behaved much better. For some reason airing down the tires has caused me more steering issues. So unless the sway bar brackets help tremendously I'm going back to the stock bracket and going with an adjustable track bar as well. I like the Lewis bar however I've never actually reached anyone there via phone or email after number attempts.
Regarding the lewis bar, I hear they are good quality and do get a lot of good feedback here on the site on the product itself. Communication with the shop, timeliness of shipping is definitely an issue. I ordered mine on 2/27, finally shipped early this week after a few follow up calls/emails.
Ordered an adjustable track bar which I'm going to try with the track bar relocation bracket. Hopefully will allow for better fine adjustments. I will say I'm so far disappointed with the fox ATS stabilizer. Waited for weeks to get it and its not that great. Feels like a rolling motion through the steering over some bumps or roadway imperfections. We'll see how the adjustable bar and the sway bar drop brackets work out. I've also tried all different air pressures.
On a side note, the last place I took my truck to be aligned suggested a tire rotation may help, as the front tires may have worn in odd manner causing some of the steering imperfections.
I was noticing that rolling feeling with the FOX ATS as well. That has gone away post level/new track bar/increased caster. I'm not sure which of those caused it to go away. I think it may be your track bar or possibly tire wear.
If you're going the adj'd track bar route, you may want to consider putting the stock track bar bracket back on. Not sure if it really matters, but I think I would be included to do that.
I thought it was one or the other but not both? I know for me I'm limited as I only have a 2" level so some of the adjustable track bars are too long to even use with only 2".
You're right, I called Carli and their's is too long to use with anything less than 2.5in of lift. Rough Country works (I have that installed now). According to Lewis, their's works from 0-4.5in of lift w/o a relocation bracket. Not sure about any others.
what size lift do you have and what radius arm drop brackets?
Rotated the tires today, that did nothing. In addition to installing the fox ats as opposed to the pressurized single ifp, if I let go of the wheel it turns slightly on its own to the right, causing me to have to hold the steering wheel at center.
Adjustable track bar is on the way, I'll have that installed with the stock bracket and have it aligned again for the 6th time. It feels like this small lift has nickel and dime the crap outta me. Not going to drive the truck until all the parts arrive.
