Sponsored by: Real Truck
Dana 60 searhing
Old Mar 20, 2019 | 12:08 PM
electryc_monk's Avatar
electryc_monk
Veteran: Navy
Red face Dana 60 searhing
over the last 2+ weeks I've tried several searches, and can't quite figure out on the method to filter down to find some wisdom and part numbers when its off the truck and getting cleaned and reassembled.
usually i end up with 300-500 and so many have stories that are great. Several have the hub assembly part #'s and a few other outside items.....
i wish i could find-out the parts diagram for the inner pieces of the pumpkin area. and their part numbers and how can you decide if they should be replaced.....
the plastic looking funnel on each inside shaft area & that splash-type rings?
Old Mar 20, 2019 | 01:09 PM
redford's Avatar
redford
FTE Leadership Emeritus
Like this?
https://goo.gl/images/uHanVj
Old Mar 20, 2019 | 04:36 PM
SuperDutyScaler's Avatar
SuperDutyScaler
It's a Dana 60, so it's the same internals since what 1960's
ball joints are either play or dryness when checked by a inch pound torque wrench. Everything else internally should be fine forever as long as the axle wasnt submerged in water and left in there
Old Mar 21, 2019 | 03:07 PM
electryc_monk
Veteran: Navy
Redford. thanks. for whatever reason when i tried google i never got the newer images or large ones. (shrugs)
SDS. The inner shaft areawhere those plastic looking funnels are has alot of F.O.D. and I've tried to PSI spray with cleaner & Air to get the gunk from that area and not been fully successful.
If I can stop by later today, I'll try and snap a pic to show the condition of the "Axle-shaft guide area and inner seal" that the pic Redford's link provided.
Old Mar 22, 2019 | 08:59 AM
brian42's Avatar
brian42
Veteran: Navy
My axle tubes were plenty dirty as the old style dust seals broke fairly quickly leaving you to either live with it or tear down the front end to replace them.
To clean mine I used various cleaning items taped to the end of a broomstick to clean them out. Things I've used to "get in there" are small hair brushes, greenies, sponges, toothbrushes, and other small things I can't remember.
I never used compressed air as I didn't want to blow any of that dust/sand/debris into the differential. The inner oil seal is only a splash guard to keep the oil in when the shaft is installed. Without the shaft that's a big hole that stuff can get into.
Just my .02
BBslider001
Oct 18, 2018 01:22 PM
BlueOvalDismantlers
Jun 23, 2012 11:35 PM
dustinova
Dec 29, 2006 07:34 PM
