Hot hub
Old Mar 19, 2019 | 07:49 PM
green_95's Avatar
green_95
Hot hub
So i had a major wheel bearing malfunction, it destroyed my spindle and both inner and outer bearings. I got a new spindle and replaced the races a.d bearings. But now whenever I drive it that hub gets really hot like the bearings are to tight, which they are not. Inner bearing torqued to 50 lbs and the outer 160lbs. I have no idea what the problem is.
Old Mar 19, 2019 | 10:57 PM
fordman67's Avatar
fordman67
​​​​​​The first nut is at 50?!?!? Lbs?!?!
thats the issue.
Old Mar 20, 2019 | 12:37 AM
Bob_T's Avatar
Bob_T
thats the issue.
Yes, way too tight. Where did that 50 ft lb number come from? I don't know what the "official" torque is supposed to be, I just tighten mine snug to take the play out, then back it off a bit. Never burned up a wheel bearing.
Old Mar 20, 2019 | 05:58 AM
green_95's Avatar
green_95
I googled it and that's what It came up with. 50lbs for the inner and 160-204l s for the outer. Guess I'll be taking it back a part and loosening them up.lol
Old Mar 20, 2019 | 07:01 AM
fordman67's Avatar
fordman67
That inner gets set to 50 to seat the bearings then backed off to basically just over hand tight plus a scosche . Then outer nut locks the deal from backing off.
Old Mar 20, 2019 | 07:27 AM
Bobcatbob's Avatar
Bobcatbob
Adjusting the bearing requires knowledge of how threads and nuts are made. There is play between the threads that must be considered.
400k on my original bearings adjusted to a very small amount of final play when outer nut is finally tightened. Takes a bit of adjusting the first nut to achive that.
Old Mar 20, 2019 | 09:43 AM
knottyrope's Avatar
knottyrope
I see hot tub for a subject and get all excited to see some pics..............
Old Mar 20, 2019 | 10:43 AM
fordpride's Avatar
fordpride
For manual hubs:
Torque the inner nut to about 50 ft-lb while spinning the hub back and forth to seat the bearings; then break it lose and tighten just enough to take the play out. Adjust the inner nut as necessary to fit the dowel pin into the lock ring. Then the outter nut is torqued to around 120-150 ft-lb.
Auto hubs are basically the same but with a locking pin that slides between the nut and the spindle and no outer nut.
Old Mar 20, 2019 | 11:18 AM
Bobcatbob's Avatar
Bobcatbob
I often wish there was a finer adjustment with the lock ring pin. It's borderline between extra play and a bit of preload. I always errored on the loose side.
Made that choice when I bought it. Used Mobil 1 grease. Was constantlty worried about too much preload. To do properly would require a special gage setup. Seems like the over the road semi-trucks have it solved.
Old Mar 21, 2019 | 06:44 AM
fordman67's Avatar
fordman67
Thank you, and here I thought I was being goofy. Then I think maybe he meant hot tub...time machine lol
Old Mar 21, 2019 | 02:43 PM
knottyrope's Avatar
knottyrope
time does go by quickly in one, that's for sure
Old Mar 21, 2019 | 06:22 PM
427 fordman's Avatar
427 fordman
Hope you got it backed off, 50lbs could hurt things in a hurry.
Old Mar 23, 2019 | 05:33 PM
green_95's Avatar
green_95
Ok so I hadn't drove the truck since last weekend. Jacked it up this morning and loosened the nuts up. I basically loosened them up and tightened them up finger tight and then put my socket on tightening while checking for wheel play. As soon as the wheel play was gone I put the lock washer on and then the 2nd outer nut on. I can not go any looser as there will be play in the wheel. I have never had trouble like this. Is it possible that the bearing races are not seated properly?
Old Mar 23, 2019 | 07:06 PM
fordman67's Avatar
fordman67
Is it getting hot still?
Old Mar 24, 2019 | 05:52 AM
green_95's Avatar
green_95
yes, It literally can not be anymore loose. Could the manual hub be damaged somehow? It looks fine and seems to function properly.
