Need torque specs
Old Mar 18, 2019 | 10:08 PM
Imadentguy's Avatar
Imadentguy
Need torque specs
Anyone have a factory repair manual that can give me the torque specs for the upper and lower bolts on the LOWER intermediate steering shaft? Thanks ya’ll
Old Mar 19, 2019 | 12:18 PM
Imadentguy's Avatar
Imadentguy
Bumping this to take it to the top. Lil’ help hea’
Old Apr 15, 2024 | 05:20 PM
Smiggles1970's Avatar
Smiggles1970
Trailering
Same question. What is the torque specs for the lower intermediate steering shaft? I have found values, but they dont seem to be related to 2017 and newer.
Old Apr 15, 2024 | 07:16 PM
SARDiverDan's Avatar
SARDiverDan
Upper steering column shaft bolt = 22 lb.ft
Lower steering column shaft bolt = 22 lb.ft
This info is from my 2019 service manual.
Old Apr 15, 2024 | 09:16 PM
Black Buzzard's Avatar
Black Buzzard
Some story might help. Why are you in there?
Old Apr 17, 2024 | 07:41 PM
Smiggles1970
Trailering
The reason I ended up swapping the lower steering shaft on my 2018 2WD with ~70K was because the needle bearings went bad in the U-Joints. There was an annoying sensation in the steering wheel where you could feel every crack in the road, especially at very low speeds. It also felt like bad tie rod ends at times. It is somewhat of a common issue across multiple model years.
Excellent...Thanks @SARDiverDan
Old Apr 17, 2024 | 07:57 PM
WXboy's Avatar
WXboy
Yep, very common on these trucks. I did my '19 not long after I bought it with 81k on the clock. Felt like something in the front end was going to literally come apart. Turned out to simply be the lower steering shaft. I put my new one in using the original bolts, tightened hand tight with a 3/8" ratchet and long extensions. Drove two weeks then checked it again to be sure. It's been fine ever since.
1989FordF250
Oct 15, 2017 10:11 PM
rtazz17
May 6, 2011 11:20 AM
5thwheeler
Modular V10 (6.8l)
Dec 21, 2003 01:58 PM
