Pluckin Puck Covers
Old Mar 18, 2019 | 10:54 AM
Platinum One's Avatar
Platinum One
Pluckin Puck Covers
I hauled several pallets of mulch this weekend and noticed afterwards a couple of my plastic puck covers on the factory 5th wheel hitch prep were missing/mangled, so wanted to ask others what they do to protect these covers when loading/hauling pallets and other materials. I guess I could put down a sheet of plywood to cover them up. Any other suggestions?
Old Mar 18, 2019 | 10:59 AM
kry226's Avatar
kry226
I have the 5th Wheel Prep Package too. I'm going to have my bed Line-X'd then install a rubber bed mat on the bed floor. I figure that'll protect the pucks well and prevent any objects from sliding around.
Old Mar 18, 2019 | 12:11 PM
bigred460ci's Avatar
bigred460ci
Rhino Liner and a rubber mat.
Old Mar 18, 2019 | 01:15 PM
HRTKD's Avatar
HRTKD
While load/unloading a couch in the bed of my truck a leg of the couch got stuck against one side of the puck rings and folded it up. I was kind of bummed about that. Maybe next time I'll throw a sheet of plywood in the bed beforehand.
Old Mar 18, 2019 | 01:51 PM
Mkos1980's Avatar
Mkos1980
Although I have linex myself I use a rubber mat over everything when not using the 5th wheel.
Old Mar 18, 2019 | 02:18 PM
wicked 2018's Avatar
wicked 2018
Factory liner and rubber mat here also
Old Mar 18, 2019 | 02:20 PM
Kaadk's Avatar
Kaadk
I just leave the hitch in the bed 24/7/365, and borrow one of the father-in-laws trailers when I need to pick up a load like that. But that doesn't work for everyone.
Old Mar 18, 2019 | 03:39 PM
senix's Avatar
senix
I have always tried to use a sheet of plywood. I have an occasion turned the plastic ring up loading or unloading. A heat gun will it to reform the proper way again.
Old Mar 18, 2019 | 03:45 PM
mrmag00's Avatar
mrmag00
I have linex and recently got a DeeZee bed mat for it to cover the holes, it was $100 at auto zone.
Old Mar 18, 2019 | 04:00 PM
Platinum One
I have line X but not sure the rubber mats will allow pallets to be pushed farther into bed to get the weight over the axle. Not sure if one bad pallet did all the handiwork on the puck covers, or if it was a combination of multiple pallets being loaded and pushed forward
Old Mar 18, 2019 | 08:06 PM
jrwinger's Avatar
jrwinger
I've had the same issue with the puck covers flying out when a pallet is loaded. I've actually had to purchase new covers because I've lost a few with loads being put into the truck. In my opinion, a bed mat is a no go when loading a pallet. It's too, "sticky" for the pallet to slide into the truck and be centered over the axle.
In the months to come, I'll have 2k pound pallets forklifted into the bed a few times a month. I'll probably just leave the bed mat in & throw a good piece of 1/2 plywood in there. The pallet will slide right in & I won't have to worry about my puck covers like last year.
Old Mar 18, 2019 | 08:33 PM
ytechie's Avatar
ytechie
Am I the only one that doesn’t use them? I have a tonneau cover, so they’re dry.
rjrandy96
Jun 12, 2019 07:02 PM
SDTruckMan
Apr 17, 2018 11:52 AM
TrailKroozr
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Mar 3, 2017 10:35 AM
Boomer23059
Apr 28, 2011 04:45 PM
TNT in Round Rock
Mar 4, 2008 11:58 PM
