2017 with 5.0L engine has no towing power
Old Mar 18, 2019 | 04:26 PM
GlueGuy's Avatar
GlueGuy
Originally Posted by HiTechRedneck1
We have to remember that it's only a 5.0 so 70 MPH in 6th gear is probably not going to happen unless it's downhill. My 5.0 also has 3.55 gears and 33" tires so it's not necessarily optimal (first tow was with 35" flywheels). Dropping back to a 33" lighter tire and wheel combo produced a noticeable difference.
Don't tell that to my 3.5L Ecoboost. At 65 it's only turning ~~ 1500 RPM and it's in 6th (top) gear. This is with the 3.31 differential. May not be 600 HP, but it has torque to burn.
Old Mar 18, 2019 | 05:55 PM
buba 11's Avatar
buba 11
Originally Posted by jr105
How does it do when not towing?
It runs smoothly when not towing, it will stay in 6tg gear when going at highway speed, say 70 mph. You can tell the motor is not to comfortable at 80 seems like it runs out of power. Somebody mentioned the air cleaner and I need to take a look at that. I'm gonna bring it in for an oil change and have the Dealer check the motor out. Just wondering if anyone noticed a performance change using 87 or higher octane gas? Do performance tuners shorten the life of the engine, cause valve or piston problems?
Old Mar 18, 2019 | 06:35 PM
jr105's Avatar
jr105
Just a guess, but it sounds like you have a restriction to the air flow, either upstream by something like the air filter or something downstream like a partially clogged cat.
Old Mar 18, 2019 | 06:54 PM
JKBrad's Avatar
JKBrad
Hopefully it doesn't turn out like the guy who bought a certified pre owned truck that never had an oil change.
Old Mar 19, 2019 | 09:27 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
LOL quit asking about the axle ratio... 3.31 wouldn't make a difference
Old Mar 20, 2019 | 12:14 PM
GABAR's Avatar
GABAR
Originally Posted by buba 11
I just bought a used 2017 f150 with a 5.0L engine. I hooked it up to my motorcycle trailer today and what a disappointment! I could barely get 70mph out of it. The truck has 34K miles on it and sounds good. Am I missing something here, the trailer cannot weight 2500 lbs. Has anyone else has this problem, what did ford do to fix it???
Try a fresh tank of 93 octane.
Old Mar 20, 2019 | 12:31 PM
ecoboost12's Avatar
ecoboost12
Have them check the Throttle body for a Malfunction or Dirty
Old Mar 20, 2019 | 02:44 PM
buba 11's Avatar
buba 11
Will do, thanks, and I am planning on putting some 93 in it just to see if it makes a difference. Perhaps some highway miles will roast out the catalytic converter?
Old Mar 20, 2019 | 04:31 PM
JKBrad's Avatar
JKBrad
Try a few wide open throttle runs up a steep grade.
Old Mar 20, 2019 | 04:34 PM
seventyseven250's Avatar
seventyseven250
When you say "barely" will do 70, what exactly do you mean? Are you saying your foot is on the floor and it's not getting there, or are you saying it needs to be at higher RPM than you are comfortable with?
Old Mar 21, 2019 | 08:04 PM
Rickyrobert's Avatar
Rickyrobert
Wide open my 5.0 hits the speed limiter (103mph? 107? I can't remeber) in 5th. Something is wrong.
Old Mar 22, 2019 | 05:26 AM
buba 11's Avatar
buba 11
Question
I was going down Rt. 495 in MA, A strait flat 3 lane highway more or less at sea level, on a 50degree day. The truck seems to be sorta OK at 65, which is slow compared to the traffic I'm driving with. I try to bring the truck up to 70, the truck goes into 4th gear, somewhere past 3000 RPM. I reach 70 and the truck is struggling to remain in 5th. Any small rise in the road puts the truck into 4th gear and I am pressing harder on the gas pedal and i'm not going faster or maintaining speed. 6th is a down-hill gear, truck remains in 5th but is more comfortable in 4th. This is with my light motorcycle trailer with one bike in it and I'm wondering how impossible it would be if I tried to tow the boat trailer. The boat trailer is near to the max Ford says this truck can handle and I think it would be impossible, I think the truck would be in 3rd and tacking on around 4500 rpm and going less that 55. NOW COME ON, ITS GOTTA DO BETTER THAN THAT. Like I said before, I'm gonna have the dealer check it out during an oil change. OTHER THAN THIS ISSUE, I LOVE IT, ITS COMFORTABLE QUIET AND RIDES LIKE A CAR.
Old Mar 22, 2019 | 06:02 AM
  #28
msgtord's Avatar
msgtord
Double check your trailer brakes. Jack up each wheel and check rotation with no power to trailer. Then plug in the trailer and check each wheel again. You can try towing the trailer empty without being plugged in. Is this a single or dual axle trailer?
Old Mar 22, 2019 | 07:40 AM
  #29
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
this whole thread is based on a subjective opinion, we cant help without any facts
Old Mar 22, 2019 | 09:09 AM
  #30
IndyDog's Avatar
IndyDog
I had a F250 with the 7.3 diesel, it pulled my 33' boat nicely. My next truck a F250 V10 didn't pull it near as well. Even though the 5.0 is considered a "big" engine, it's still a 5.0 and limited in its ability. So subjectively I thought my V10 pulled poorly but compared to my 5.0 it would be a monster.
Subjective as it may be, it does seem a bit strange that it would have to be in such a low gear to pull a motorcycle.
