Alternator or batteries??
Old Mar 17, 2019 | 11:44 AM
MAKO314's Avatar
MAKO314
ok so I hopped in my SD to go to Lowe’s this morning it started fine but turned a little slow. I drove to Lowe’s and went in and got what I needed and came back out, no start. It turned really slow and would not start, I have a small capacitor so I connected it to the cranking battery and it fired right up. Now going back to the house I noticed that the battery gauge was steadily dropping the longer the truck ran and when I did get home it was dead to the point that it wouldn’t even turn over. My question is, would this point to a bad alternator or bad batteries? The batteries are around a year old and I have no idea about the age of the alternator? Thanks for any help...
Old Mar 17, 2019 | 12:03 PM
seville009's Avatar
seville009
If the battery voltage is decreasing while the engine is running, generally that means the alternator isn’t charging it.
Old Mar 17, 2019 | 01:40 PM
MAKO314's Avatar
MAKO314
i replaced the alternator and charged the batts everything seems to be ok now. The alternator is putting out 14.6 volts and the batts are maintaining while the truck is running on 1100 rpm fast idle with the A/C, headlights and sound system all on.
Old Mar 17, 2019 | 03:42 PM
seville009's Avatar
seville009
Sounds like you fixed it.
Old Mar 17, 2019 | 04:52 PM
kbeefy's Avatar
kbeefy
did you check running voltage at batteries before changing anything?
Old Mar 17, 2019 | 06:16 PM
MAKO314's Avatar
MAKO314
i had the parts place check the alternator on their bench. It wasn’t putting anything at all out. But to answer your question, no I didn’t check anything before the swap. Both batts were down below 10 volts and had to be charged for a couple ours before they had enough juice to start the engine. I then checked the alt output and it was good. The batts are both on chargers now to get them all the way up.
Old Mar 17, 2019 | 10:05 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Load test those batteries before using them, so you don’t get stranded. Alternators are known for taking them out. If your batteries are going bad, they will load down your new alternator.
88_F0RD
Dec 6, 2016 07:53 AM
Trav1990
Nov 6, 2016 09:29 PM
stevorino
Apr 25, 2012 06:45 AM
sprint406
37
Feb 21, 2012 06:25 PM
strokin'_tatsch
16
Apr 2, 2008 10:35 PM
