GVWR
Old Apr 6, 2019 | 10:16 AM
  #31
PaleRider01's Avatar
PaleRider01
I found that the all season tires are rated lower than the all terrain tires. I'll try to find that info and post.
Old Apr 6, 2019 | 11:29 AM
  #32
UGA33's Avatar
UGA33
PaleRider, I noticed you had the 160” WB 350 with an 18k conventional tow rating. It is only 15k.
Old Apr 6, 2019 | 11:50 AM
  #33
PaleRider01
I saw that too on the ford brochure but the 18K I got off a different spec sheet. I'm gonna try to find that, I may have put the wrong data on there. Ill check and repost. Thank you.
Old Apr 6, 2019 | 11:59 AM
  #34
UGA33's Avatar
UGA33
Yeah. There was a LOT of misprinted ratings during the launch that left a lot of us here on FTE scratching our heads. It is the reason when Ford finally figured out their numbers, they dropped the 3” receivers from the 160” WB 350 SRW trucks to better align the truck’s equipment with its 15k tow rating.
Old Apr 6, 2019 | 12:00 PM
  #35
PaleRider01
UGA33
Your are correct sir. I must have grabbed the number next to the box I should have. Plus wish
full thinking I bet. pulled from the 2019 RV & Trailer Towing Guide.
Old Apr 6, 2019 | 01:17 PM
  #36
UGA33's Avatar
UGA33
Its extremely dumb they don’t give it an 18k conventional rating when the same truck minus badges has it.
Old Apr 6, 2019 | 01:53 PM
  #37
sdetweil's Avatar
sdetweil
only the long bed has the 18000lb rating. More chassis to deal with the tongue weight.
Old Apr 7, 2019 | 06:47 AM
  #38
crewzer's Avatar
crewzer
Lightbulb
The 18” AS tires are a smaller size than the AT tires, hence the lower load rating.
HTH,
Jim / crewzer
Old Apr 7, 2019 | 07:37 AM
  #39
PaleRider01
You Got It! That's exactly where I saw it. That is an excellent document.
BPCheeta
All Things Towing
Jun 9, 2017 12:59 PM
roadkingfl
6.7L Power Stroke Diesel
Oct 17, 2012 08:42 AM
Oakland60
Nov 12, 2011 04:49 PM
hikeril
56
Oct 18, 2011 01:15 PM
System
Mar 26, 2009 06:32 PM
