OEM tow control 2011 E350
Old Mar 16, 2019 | 11:59 AM
ALO604's Avatar
ALO604
I have an 2011 E350 superduty chassis class C motorhome. I'd like to install the OEM dash brake control.
I've got mixed advice from Dealers if will actually work. The OEM trailer wiring is there and 7 way trailer plug.
Does anyone have real world advice on this install? I've done the internet search thing.
Please don't assume or guess the answer, have you done it.
Old Mar 16, 2019 | 08:00 PM
senix's Avatar
senix
If the wiring is there, then it maybe possible. But the wiring in the dash also needs to exist.
I don't know about the E chasis on whether they could come with the TBC or not. If there is a spot for it below the HVAC controls then I suggest taking the center stack cover off to see if the wiring is there. If so then a it can just be plugged it.
To actually activate it you would need to visit a dealer or have someone who can go into the PCM and turn the function on.
Old Mar 16, 2019 | 09:22 PM
ALO604's Avatar
ALO604
Thanks but what did I say about assuming or guessing. I need a reply from someone who has actually performed this task.
Like I said all the OEM wiring is there.
Old Mar 16, 2019 | 10:45 PM
lhoward1134's Avatar
lhoward1134
I would do a search over in the van section of this forum. A few years ago I was hoping to do this to mine, an '06, but I think I read the factory TBC started in '10. I can't remember if anyone ever added a TBC, but that's where I would look.
Old Apr 13, 2019 | 10:54 AM
bellport's Avatar
bellport
I added an aftermarket brake controller to my E-450 U-haul it took about 10 minutes to hook up, very easy plug and play
Old Apr 13, 2019 | 01:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The3 OEM Ford TBC requires a special Master Cylinder. If you do NOT already have it ( if the van didn't come with the TBC you can assume you don't have it) it will be MUCH simpler to just install an aftermarket controller. Ford's TBC started in 2005 vehicles. I looked up your best bet for you. https://www.etrailer.com/bc-2011_For...l=-pm-Tekonsha
I removed my troublesome factory TBC and installed this also.
khite
Jun 13, 2019 03:49 PM
DSE350
Apr 8, 2015 04:23 PM
brassspike
Oct 12, 2012 08:38 AM
dcramp
All Things Towing
18
Feb 26, 2007 09:25 PM
khensley
All Things Towing
Feb 12, 2002 02:27 PM
