2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Do you think FORD prefills new oil filters?
Old 03-16-2019, 10:02 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
since the 6.7 has an oil filter that installs upright , it would be nice if FORD prefilled the new filter before install. I would be happy even with a partially pregilled one.
anyone know if prefilling is SOP
Old 03-16-2019, 10:19 AM
Sport45's Avatar
Sport45
Sport45 is online now
I doubt it. I've been at several industrial engine manufacturing facilities and haven't seen this done before. There's generally plenty of assembly lube to take care of everything before the oil starts flowing.
I've never pre-filled an oil filter and usually run my vehicles to 185-250,000 miles with no engine problems.
Old 03-16-2019, 10:26 AM
69cj's Avatar
69cj
69cj is offline
If pre-filing was necessary there would be no horizontal or upside down oil filters.
Old 03-16-2019, 10:41 AM
mattymax's Avatar
mattymax
mattymax is offline
I would say no they probably don’t waste their time.
One of the reasons I do my own oil on all my vehicles. Does it matter over the life? Who knows
Old 03-16-2019, 10:44 AM
Joe T's Avatar
Joe T
Joe T is offline
Naw and i doubt they pop right off so plenty of priming while turning over.
I personally like to prime filters some when I lube the gasket. Pretty easy unless it like in a factory or a place you have 2 people and an oil gun.
kry226's Avatar
kry226
kry226 is offline
I'm fully convinced it's a waste of time.
Old 03-16-2019, 10:59 AM
honda250xtitan's Avatar
honda250xtitan
honda250xtitan is offline
my walker mower Kohler motor filter calls for it to be pre filled...even though its a horizontal mount. so thats a nice mess every time. lol. So then i did the same on the f150, also horizontal but a stupid tight fit, another huge mess. i shouldn't play mechanic anymore.
flanneljunkie's Avatar
flanneljunkie
flanneljunkie is offline
I'm in agreement with everyone else. I doubt Ford does. Do I? Only if the filter is vertical and right side up. As is the case with many vehicles, how the hell do they expect you to prefill a filter when it attaches horizontally to the side of the engine?
Old 03-16-2019, 11:02 AM
Xwild's Avatar
Xwild
Xwild is offline
Pretty obvious.. simply lift up the far side so the filter gets installed vertical
Old 03-16-2019, 11:17 AM
Sport45's Avatar
Sport45
You can also consider that any oil you pour into the filter will not be filtered before circulating through your engine...
Why New Oil Should be Filtered
Old 03-16-2019, 12:17 PM
UGA33's Avatar
UGA33
UGA33 is offline
Highly doubt they do. When I did the Ford KTP tour, one of the most painful things to hear was them busting off the 6.7 trucks at the end of the line for the first time. Let’s just say no one was Key On/Engine OFF priming the fuel systems. Poor HPFPs were probably hating life.
Old 03-16-2019, 01:16 PM
willynilly's Avatar
willynilly
willynilly is offline
some toyota filters are upside down and they seem to make it a few hundred thousand miles. which reminds me, upside down makes more mess when changing and it was a stupid idea on toyotas part
Old 03-16-2019, 02:05 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Well if I had to wager, the engines leave the factory dry because they aren't hot running the engines. It also would make for easier paperwork to not have to classify all that oil on shipping manifests when they import the engines to the USA from Mexico.
Old 03-16-2019, 02:51 PM
69cj's Avatar
69cj
69cj is offline
The wife's Mercedes filter is upside down. I'd love to watch someone pre-fill it. When first loosened it let's a drain valve open so that there's no mess.
Old 03-16-2019, 03:38 PM
RGPolo's Avatar
RGPolo
RGPolo is offline
Same here, been prefilling filters my whole life. Probably a waste of time, but makes sense to me. On the other hand, upside down filters never made sense to me, but what do I know? Just an old school, common sense Conservative.
Quick Reply: Do you think FORD prefills new oil filters?
