Choke is stuck
Choke is stuck
Hey guys, this one is a unique problem for me. I looked around on the web and cannot locate any threads with the 7.3 choke. Basically it is stuck "on" and won't let the truck return to normal idle. I see/saw there are manual choke kits for the gas engines, but are there any for the 7.3? Or, are there any known threads dealing with this issue with pictures?
Received 3,263 Likes
on
if you are stuck on high idle, you can unplug the wire off the fast idle solenoid on the passenger side of the injector pump rite where the throttle arm is. if the idle drops, the problem is in the high idle circuit. if it does not, it is in the throttle cable or pedal .
my bet is a frayed throttle cable not letting it return to idle.
PitbullsAndFords
10-03-2007 11:56 PM
HotWhlz85
11-04-2002 02:21 PM
