Sponsored by: Real Truck
Leveling kit info
Old Mar 15, 2019 | 11:56 PM
Dutter 2's Avatar
Dutter 2
Leveling kit info
So I got my 2012 f350 with a leveling kit, but I actually use my truck for towing so I gotta 5.5 inch block for the rear raising it 2 inches But the handling of the truck feels off. While steering it feels like my track bar is hella loose but she’s tight. Is this normal ? Or is it from the leveling kit? If so what part would help that. Like a track bar drop or radius arm drop ? And finally is there any pros to longer coils vs spacers ?
Old Mar 18, 2019 | 09:04 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
I have always relied on a good front end/alignment shop to help with problems as yours. Get professional help.
Old Mar 18, 2019 | 09:17 AM
Dutter 2's Avatar
Dutter 2
It’s a straight axle. There is no caster or camber adjustments. Just tow, and tow dosnt effect handling unless it’s way off
Old Mar 18, 2019 | 09:14 PM
Eaglescout94's Avatar
Eaglescout94
There are adjustments, I believe it’s a rotating shim or collar with the ball joints.
Old Mar 18, 2019 | 10:56 PM
Dutter 2's Avatar
Dutter 2
On twin I beam yes
Old Mar 19, 2019 | 05:49 AM
Deuce40s's Avatar
Deuce40s
Originally Posted by Dutter 2
On twin I beam yes
Camber and caster can be adjusted with bushings/shims, etc. You need your caster angle fixed, probably with radius arm drop brackets.
Arkguy
Mar 28, 2019 05:13 PM
KingofBolivar
Dec 23, 2017 09:31 PM
cbzdel
Jan 9, 2012 09:45 PM
Waffle17
Feb 17, 2011 06:32 PM
jjsniper32
Mar 17, 2010 09:44 AM
