Anger management
Old Mar 15, 2019 | 12:08 PM
Rasputin53's Avatar
Rasputin53
Anger management
I said straighten up!
Got out the hammer/dolly set (HF) and decided to do something about the push in on the front passenger side. Nose is still off from the motor install. Finally getting back to that. Here's a few before and after pics. Not too shabby for my first real try at this type of body work. Lower fender, corner piece and gravel pan all needed massaging. Still needs sanding and paint, but I'm pretty pleased that all the round surfaces are back. The rust, scratches and missing paint make it look worse than it actually is in the 'after' shots. I got the rip in the corner piece to line back up. Going to lead that one, old style. On to the bumper. Going to need to use the press on that one.
Before
After
Before
After
Another Before
Old Mar 15, 2019 | 02:57 PM
GLR's Avatar
GLR
Not bad for a rookie, Ed
Did you ever get that exhaust manifold you were looking for?
Old Mar 15, 2019 | 04:37 PM
Rasputin53's Avatar
Rasputin53
No. A buddy braised it up for me. I fully expect that to fail after a few cycles which will then justify the headers.
Old Mar 15, 2019 | 06:10 PM
GLR's Avatar
GLR
Ok Ed, I brought one down from NY. I foresee headers in the future for a couple of our projects too.
Old Mar 16, 2019 | 02:47 AM
GaryKip's Avatar
GaryKip
That came out very nice! Keep up that kind of work and there'll be a body shop next to the house by the end of this summer-lol.
Old Mar 16, 2019 | 04:08 PM
Rasputin53's Avatar
Rasputin53
On to the bumper. Didn't take a 'before' prior to the press work. Used the 20T to push the bumps and dips on the top and bottom edges back to straight. That really got rid of the deflection towards the rear. All that was left was twist that was from the mount to the passenger outside edge. Made a lever out of some board scraps and 250# of Polack butt later, I'm happy with the results. Did do some fine tuning with the 4# hammer to get the top line just right. Used a digital level on the back to match the angle with the driver's side which was not damaged.
Note the angle of the back edge. It goes towards the tire as it goes down.
And now they are essentially parallel.
Old Mar 17, 2019 | 01:38 AM
GaryKip's Avatar
GaryKip
Cool bumper adjustment tool. I'll have to keep that design in mind.
KrisEvans
27
Nov 21, 2015 10:52 PM
Johnny L
41
Mar 17, 2015 04:38 PM
Green_Dually
16
Dec 17, 2011 06:58 PM
Mffix
Projects
17
May 4, 2011 07:14 PM
swampshaker99
23
Nov 2, 2010 02:53 AM
