Compression Test: '03 E350 5.4l Auto
AALSO: Only one cylinder reporting misfires (#2) ya'll know what a challenge is to pull the COPs & plugs, I just want to pull cylinder #2 get a few readings then pull cylinder #1 to compare, total waste of time or what? ALL other cylinders are reporting zero misfires in the Mode $06 Monitoring.
thanks a ton.
While it is apart, check the electrical connectors for the coil and injector to be sure they have power and that the clip locks to hold them connected. It may be a good idea to have a spare new coil to put back on in case the coil is the issue, new coil should include a new boot as well so two birds maybe.
Also, you should keep the same issue on one thread so anyone that might be inclined to help you has all the info without cross referring to different threads.
I actually found a remote starter switch at Harbor Freight today for $10 so I committed to going under the van and rigging that up today. Tested 3 cylinders and got the same exact reading on all three, three separate times so I am hopeful that Cylinder #2 is AOK in that respect.
thanks for the reminder to try a different coil! I already put the original back on the new plug so I will think about what I want to isolate: plug, coil or injector. or decide I don't care just put replacements of each on that cylinder. I could move the coil to cylinder #1 and the injector to cylinder #4 and see if the misfires; disappear, migrate or multiply! hehe
