Sponsored by: Auxito
lights problem
Old Sep 30, 2003 | 09:26 PM
StillBlue98's Avatar
StillBlue98
Question lights problem
I have a 98 F150 SC 4X4. Every now and then, My turnsignals don't work. I can turn the lever off and back on and they start working again. Last night, I turned on my headlights, and they didn't work. I had dash lights and tail lights, but no head or fog lights. I drove home on back streets, and once when I hit the turn signal, the headlights came back on. Tonight they work fine again. I'm guessing its the multi function switch on the steering column causing the problem. Have any of you seen this, or know how hard it is to change? Thanks in advance
Old Sep 30, 2003 | 10:08 PM
LxMan1's Avatar
LxMan1
Yep, sounds like the switch is going. It should be pretty sinple to replace. Remove the column cover, unplug all of the plugs, unscrew the switch from the column. Just reverse to install the new one.
Jimmy
