Brake light wiring
Old Mar 13, 2019 | 04:01 PM
billybobw4's Avatar
billybobw4
8th Gear
Brake light wiring
Hello,
I received a tailgate brake light bar for Christmas and it does not work properly on my truck when plugged into any of the trailer connections as my truck has trailer recognition. It does not matter if I plug into the 7 pin connectors or the 4 pin. I tried adding resistors to the light bar and that did not allow the light bar to work correctly either. I plug the light bar into other vehicles and it works just fine so I know the bar is good. I found a thread that talked about hard wiring the light bar to the truck taillights (not trailer) but do not want to cut into my factory harness. I purchased both male and female connectors to make my own little pigtail (adapter harness) so I can just unplug it if I ever want to remove it and be back using the factory uncut wires. My truck has BLIS as well so the drivers (left) side harness has 9 wires and the passenger (right) side harness has 10 wires. Does anyone have a wiring diagram that shows the wire colors for the harness that connects directly to the taillight housings so I can be sure I am using the correct wires?
1carguy
2015 - 2020 F150
Jan 23, 2018 05:00 PM
Mr Al
2015 - 2020 F150
17
Dec 14, 2017 10:14 AM
dieselsmoker
6.4L Power Stroke Diesel
May 11, 2013 06:22 AM
nut1605
Feb 20, 2011 08:45 AM
00excursion
Apr 13, 2007 08:32 PM
