Engine swap process tips
Old Mar 12, 2019 | 08:54 AM
8pack's Avatar
8pack
1955 F250
I am waiting on delivery of my truck from Kansas. The engine is seized (223) and I have a running one from a '60 ready to swap in. I could probably figure it out when I get it with some studying but having some tips in advance helps avoid reinventing the wheel. So a few questions...
-What are the best engine mounting points on a 223 to connect the engine hoist to?
-What is the best way to connect the chains to the engine? Is there a plate like on a Chevy 350 or a bracket or just bolt chains to the block somewhere?
-Does the grill, core supoort or any other parts of the front end need to come off or can you get the engine high enough to get over the grill.
-If not do you put it in dropped jack stands to get the body lower?
-I am sticking with the existing 4 speed. Does the transmission need to come out with the engine or can I leave it in. If I leave it in are you just blocking it up to hold the front in place?
​​​​​​​-If taking out the transmission does one if those angle adjusters help or is it easy enough to just manhandle the tailshaft past the firewall.
-Any other tips would be really appreciated to help me avoid unnecessary mistakes or complications .
Thanks!!
Old Mar 13, 2019 | 05:20 AM
FortyNiner's Avatar
FortyNiner
It is much easier to remove the front clip than to work upside-down. If you know that the tranny will bolt cleanly on, you can leave it in. Since we don't know exactly which engine is going in, only you can answer that question.
Old Mar 13, 2019 | 10:16 AM
8pack's Avatar
8pack
Thanks,
Was hoping I didn't have to take the front fenders etc. Off. Will the whole front clip come off as a single unit....fenders, core support etc?
I was under the impression that the 223 IL 6 engine from a '60 F100 was the same as one from a '55. I am replacing like for like if I have it right.
Old Mar 13, 2019 | 10:38 AM
8pack's Avatar
8pack
Thanks,
Old Mar 13, 2019 | 10:46 AM
52 USCG Panel's Avatar
52 USCG Panel
I was able to pull my 215 I6 engine without removing the front clip. I separated the engine from the transmission, however.
Jim
Old Mar 13, 2019 | 11:01 AM
Hotrod350's Avatar
Hotrod350
Originally Posted by 8pack
1955 F250
Bolt holes either some of the head bolts or there are several hols on the block that can be attached too.
There is a special tool that attaches to the block to help lift it, if this were the fifty's it would be available :P Best bet is chains direct to the engine.
If just taking the engine, the hood will have to be removed, a hoist will not have enough clearance to lift the engine with it on.
No ideas
98% you have to take it out. In my case I have a 223 with a 4 speed in my 55 F350, the 4 speed is only attached via the engine itself. No external mounts hold it in.
An angle adjuster will most likely help but as mentioned above taking the whole front clip off would most likely be useful.
Change your engine mounts, don't reuse the old ones. I spent at least a month fiddling with my clutch because brackets between the frame and transmission were not lining up. All because my old engine mounts were worn. Also, get the 1953-1956 ford truck manual, lots of good information on all of the truck variants.
Thanks!!
​​​​​​​Hopefully that information helps.
Old Mar 20, 2019 | 09:19 PM
8pack's Avatar
8pack
Thanks for all the replies. Everything helps! I will post an update when I get the swap done. ANy other tips still welcome!
mos68x
Jun 12, 2015 08:48 AM
Jalopy48
Large Truck
Jul 29, 2010 04:08 PM
Jalopy48
17
Jul 29, 2010 10:48 AM
Quick444
150
Feb 14, 2010 08:54 PM
Gil Chesterton
Engine Swaps
Feb 28, 2005 05:23 PM
