Carli Track Bar
Old Mar 12, 2019 | 08:11 AM
jlalanas's Avatar
jlalanas
Carli Track Bar
Anyone know if the Carli track bar is usable on lifts less than 2.5in?
Old Mar 12, 2019 | 10:30 AM
wicked 2018's Avatar
wicked 2018
Since its adjustable, from what I understand it barely works on 2.5" as it was meant for the 4.5". I also heard they were going to have a new part number for the 2.5" - not sure if this ever happened. But also locks you into a single height (should you ever want to change)
I would go with a Lewis Built or PMF adjustable - same price or less, plus its adjustable. Personally I chose Lewis built - works from stock to 4.5"
Old Mar 12, 2019 | 10:36 AM
jlalanas's Avatar
jlalanas
Originally Posted by wicked 2018
Since its not adjustable, from what I understand it barely works on 2.5" as it was meant for the 4.5". I also heard they were going to have a new part number for th e2.5" - not sure if this ever happened.
Thank you, just called carli. Their track bar works w/ the 2.5in lift in the shortest setting so will not correctly align the front with anything less than 2.5.
I have a Lewis on order, but they seem to be MIA (not answering calls/emails) so not sure when that will show up, very frustrating.
Old Mar 12, 2019 | 02:45 PM
llmflyfisher's Avatar
llmflyfisher
Carli for gasser
Just visited with Dan @ Carli and he said they have not yet started revising the spring rates for 6.2, or shock valving.
They are starting on producing the torsion away bar for the front end, unfortunately also for diesel only. But they do have plans to do a couple of setups for the gas engine trucks, but not over 2.5" lift because less power to move really big tires (37" to 40").
So for now, gassers gonna hafta find another way.
Old Mar 12, 2019 | 05:28 PM
honda250xtitan's Avatar
honda250xtitan
Torsion sway bar will be baller.
Old Mar 12, 2019 | 05:32 PM
wicked 2018
for sure - wonder when they'll release it
allingeneral
May 12, 2017 03:42 PM
shark1979
15
Sep 30, 2010 05:22 PM
mstiles19
Jul 22, 2007 02:00 AM
78fordranger
Dec 17, 2006 10:20 AM
hc130flyboy
May 24, 2005 08:24 PM
