pink vacuum line
Old Mar 10, 2019 | 06:58 PM
bigcrunch's Avatar
bigcrunch
pink vacuum line
On a 1997 f350 460 - 7.5 where does the pink vacuum line go on the right side of motor? I have the other end on the solenoid located on the left valve cover. I can not find the broken end on the right side.
If you have a pic that would be great... thanks.
Old Mar 10, 2019 | 07:13 PM
timbersteel's Avatar
timbersteel
Memory is a bit fuzzy, But, the pink line runs to the Combination/Diverter valve for the emissions tubing. It should come off either the TAB/TAD solenoid.
There should be also a Yellow vac line that runs to the Combination/Diverter valve.
Old Mar 10, 2019 | 07:28 PM
bigcrunch's Avatar
bigcrunch
I looked for a nipple on the Combination/Diverter valve did not see one. My 92 has it there not the 97.
Old Mar 10, 2019 | 07:30 PM
sandymane's Avatar
sandymane
You should have a vac diagram on your hood that should help if it is still there. Sandy
My 91 goes from the TAB to the combination diverter and attached on bottom and is very hard to see the connection.
Old Mar 10, 2019 | 08:37 PM
bigcrunch's Avatar
bigcrunch
No hood, I tried google with the diverter valve nothing useful.
Old Mar 10, 2019 | 08:42 PM
subford's Avatar
subford
Here is the pink vacuum line on my truck.
Old Mar 10, 2019 | 08:43 PM
jackietreehorn's Avatar
jackietreehorn
Goes to diverter on 97 5.8 L
Old Mar 10, 2019 | 08:56 PM
bigcrunch's Avatar
bigcrunch
Subford that was it, I to twist it over to see it... thanks for the help. Thanks to all for the input!
grizz3000
Jun 18, 2011 03:41 PM
kirbykoon
Feb 28, 2010 07:11 PM
Gunner33
May 11, 2009 07:08 AM
straightsixer
Mar 5, 2009 03:17 PM
rbastedo
Aerostar
Sep 9, 2002 07:51 PM
