Headlight harness woes
Old Mar 10, 2019 | 04:32 PM
Captain Call's Avatar
Captain Call
So I finally got around to the relay headlight harness install...but it doesn't "plug" in to my existing harness. Is this common? Here's the two plugs, the original and the new relay one. Did I somehow get the wrong one or is my pickup all fubar?
Old Mar 10, 2019 | 05:05 PM
MixWizard's Avatar
MixWizard
That looks like it should plug into one of the original headlight bulb plugs, without seeing a diagram of the relay kit wiring that's my guess anyways.
Old Mar 10, 2019 | 06:05 PM
John89's Avatar
John89
Where did you get your kit from? I am thinking about this upgrade too.
Old Mar 10, 2019 | 06:51 PM
JD Q's Avatar
JD Q
Here is a diagram of my harness.
Old Mar 10, 2019 | 06:56 PM
Captain Call
Not the plug for the light, that one is the same as the light. This is the one that is "supposed" to plug into the existing truck side.
Bought it from Bronco Graveyard.
Same diagram.
I understand the schematic side of it. What I don't understand is why the plug on either my side or their side is "off".
Old Mar 10, 2019 | 07:02 PM
JD Q's Avatar
JD Q
Old Mar 10, 2019 | 07:06 PM
John89's Avatar
John89
Okay, so you don't remove any of the original and plug this into the existing female plugs that went to the bulbs?
Old Mar 10, 2019 | 07:16 PM
JD Q's Avatar
JD Q
I your second pic is the OEM 4 pin connection. This connection remains connected as is. The new harness has three 3 spade connectors, one male two female. Disconnect the bulb passenger side of the truck, I believe, and plug the male & one female to that location. The other 3 blade female connection plugs into the driverside bulb.
Old Mar 10, 2019 | 07:19 PM
MixWizard's Avatar
MixWizard
Maybe this is a bit clearer how everything hooks up...
Old Mar 10, 2019 | 07:27 PM
Captain Call
Ok so I misunderstood the directions I take it. The plugging goes on at the light for both. Seems odd but when I get back home from picking my wife and newborn up from the hospital I'll take another look. Thanks for the replies
Old Mar 10, 2019 | 07:29 PM
MixWizard's Avatar
MixWizard
Congrats !
Old Mar 10, 2019 | 07:57 PM
John89's Avatar
John89
Yes. Congrats. You probably want to wait until your wife and newborn are both asleep. And make sure you can hear your wife if she calls for you. If this is your first, this is your real project. Worth every minute and dime. Good luck to you.
Old Mar 10, 2019 | 07:59 PM
Captain Call
Our 3rd. No big deal.
Anthonyawh
2004 - 2008 F150
Jan 4, 2019 03:54 PM
AbandonedBronco
1978 - 1996 Big Bronco
Jan 19, 2016 09:45 AM
honeydew
Ford Truck Parts for Sale
Mar 1, 2013 07:16 PM
Bullitt390
1983 - 2012 Ranger & B-Series
May 8, 2011 08:49 AM
hacking_in2002
Electrical Systems/Wiring
Dec 2, 2008 03:05 PM
