What is this part called?
Old Mar 10, 2019 | 11:12 AM
lambchops25's Avatar
lambchops25
This little square nut is what the seat bolts attach too to secure the seat to the floor. I'm needing new ones, but I don't know what the correct name is for this part, and I've been having a rough time finding it. Any help would be much appreciated. Thanks.
Old Mar 10, 2019 | 12:04 PM
FuzzFace2's Avatar
FuzzFace2
You will not find any like that as that type is crimped to the panel it is on.
You might be able to find a caged nut in the size you need, don't know if the right size it is just a picture I found of one.
http://www.steinertractor.com/IHS946...iABEgKf8PD_BwE
If it was me I would find grade 8 bolts & nuts with some large fender washers to spread the load out and nock washers to replace that nut you are holding.
Or you could tack weld that nut or new ones to the floor but again the load in at just that small point, a large fender washer spreads the load out over a larger area.
Dave ----
Old Mar 10, 2019 | 12:59 PM
lambchops25
Thanks. I like your idea better.
RA101725
May 1, 2019 10:17 AM
rsh1966
May 5, 2018 01:50 PM
Arnold Kenyon
33
Sep 1, 2016 08:43 AM
thunderbirdcakes
Apr 2, 2013 09:14 AM
TyBragg
19
Oct 26, 2012 06:26 AM
