Oil Change Question
Old Mar 11, 2019 | 01:54 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Originally Posted by sailorman3
My question was related to the on board computer that tells you when to change the oil. If the truck uses conventional oil, the computer should be set lower for the oil changes.
Originally Posted by GABAR
I’m 99.9% sure that the computer in the truck will base the oil change on a combination of vehicle factors such as mileage, hours of use, and other parameters. I really doubt that it has anything to do with mineral, synthetic blend, or full synthetic oil and the oil change suggestions on the bottle.
I’m sure your correct. It would also use speed and trailer towing. Conventional oil is in it now. I’ll go 5000 km on it and then change it to a synthetic blend. I will go to the dealer on Monday and try to find out what kind of oil was in it from the factory.
The computer counts from zero regardless. If it could be field-reset by anyone doing an oil change then many of the oil change shops would likely reset it to 3,000mi/5,000km to drum up business.
I agree with your direction. Use this adequate conventional oil for a short period (with the weather starting to warm up) then change to something better. Personally, I'd do full-synthetic, but Blend is definitely better than conventional.
Old Mar 11, 2019 | 02:05 PM
GlueGuy's Avatar
GlueGuy
Gabar is correct here. Ford calls it IOLM for "Intelligent Oil Life Monitor", and it considers a number of factors, not straight mileage.
From the Ford web site:
Your vehicle is equipped with an Intelligent Oil-Life Monitor (IOLM) that determines when you should change your engine oil based on how your vehicle is used. By considering several important factors in its calculations, the IOLM helps ensure that your engine can perform at its best while also helping you avoid unnecessary oil changes.
With the help of the IOLM, you don’t have to remember to change your oil on a preset mileage-based schedule. Your vehicle will let you know when it’s time for an oil change by displaying a message in the information display.
The following table provides examples of vehicle use and how each scenario can affect oil change intervals. In practice, actual oil change intervals will depend on several different factors, but severe usage will generally require more frequent changes. Also, if it’s been more than a year since your last oil change, the IOLM will display a reminder message regardless of your mileage.
I got this all from,here.
That link includes a general description of Normal, Severe, and Extreme driving conditions along with an estimated mileage for each.
Old Mar 11, 2019 | 03:47 PM
ecoboost12's Avatar
ecoboost12
Hay aren't they calling Conventional oil DYNO oil a Fossil fuel I believe in Motorcraft full synthetic Oil and once a year a least change
Old Mar 11, 2019 | 04:00 PM
ford390gashog's Avatar
ford390gashog
Didn't we all learn years ago the EcoBoost is not capable of going past 5k before the fuel dilution sends wear metal through the roof!
Old Mar 11, 2019 | 05:02 PM
CathedralCub
FTE Community Team
Agree. I didn't mean distance, but rather meant whatever counter it accumulates on. I probably should have said:
"The computer counts from zero to whatever threshold it crosses to decide that it's time to change oil based on how the vehicle is operated."
My point at the time was that: There is no easy way to reset that interval to be shorter or longer based on the type of oil used etc.
. . . with an implied: Thank goodness.
Old Mar 11, 2019 | 05:29 PM
idrive's Avatar
idrive
Unless I missed someone mentioning it, the IOLM can be reset to any percentage. You can set it to go off at ex. 50% if you want it to not go past 5k miles before the warning tells you to change it.
Unless I was running full synthetic I would never reset the IOLM and change it when it said to. You're basically going to be changing it at 10K miles or one year, whichever comes first. The IOLM has no idea what type of oil you're using.
I would find it hard to believe conventional oil would be adequate/capable of protecting your engine up to 10K miles...
hotrodracer
Sep 13, 2009 11:45 PM
claycomotrucks1991
Jun 17, 2009 07:17 AM
bynan2007
2004 - 2008 F150
19
May 20, 2009 02:48 PM
rm2092
2004 - 2008 F150
Sep 28, 2008 09:32 PM
ezed3354
Oil & Lubrication
Apr 6, 2005 03:45 AM
