2002 Excursion 4x4 V10 ?? Electrical ??
Old Mar 8, 2019 | 05:25 PM
Nowrenchnick's Avatar
Nowrenchnick
Hello all, I'm new to this. So here I go with my issue! I switched out my cruise control servo the other evening, however I failed to unhook battery. With that said, I have created an electrical situation for myself!!! After installing new servo I now have a blank or inoperable eatc, no power to the 4x4 shift switch, and my park safety switch will not release. Any ideas on where I should start for a repair? Could it be my PCM? Any help or suggestions?
Old Mar 8, 2019 | 05:45 PM
maypo59's Avatar
maypo59
Maybe post in the appropriate forum? This particular area is for 2017 and newer Super Duty Pickups.. While we most undoubtedly have some people with some Excursion experience, maybe go to the area just for those, where most of the members know your truck.
https://www.ford-trucks.com/forums/forum29/
Old Mar 8, 2019 | 06:31 PM
Maxium4x4's Avatar
Maxium4x4
Got you moved.
Old Mar 8, 2019 | 07:00 PM
Nowrenchnick
Thanks, new to this. Guessing moved me to an Excursion
Old Mar 8, 2019 | 07:26 PM
Nowrenchnick
Any help appreciated!
Old Mar 8, 2019 | 08:54 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You have checked all fuses?
Old Mar 9, 2019 | 11:13 AM
Nowrenchnick
Yes checked all fuses. The fuse 28 10 amp was burnt. I replaced it and.have nothing.
Old Mar 9, 2019 | 12:14 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
You need wiring diagrams. 02-03 are the same. 00-01 completely different from 02-03. Figure out where all those circuits have a common origin/power distribution and work from there back. It is easier than you think if you have the wiring diagrams.
Old Mar 9, 2019 | 02:29 PM
R&T Babich's Avatar
R&T Babich
Fuse 28 according to the 2002 Wiring Diagrams books is for the Climate Control System.
Recheck fuses 27-15A and 34-10A, those provide power to the Speed Control Servo.
Shieldslinger
Jun 9, 2015 01:50 PM
chmiller85
Jan 5, 2011 01:19 PM
funkyp excursion
Large Truck
Sep 6, 2010 12:54 AM
