ZF synchro problem
Old Mar 8, 2019 | 01:06 PM
Kapusta's Avatar
Kapusta
ZF synchro problem
.............problem solved
Old Mar 8, 2019 | 01:11 PM
ford390gashog's Avatar
ford390gashog
Don't attempt to fix it just sell it as is. The ZF5 is a real PITA and requires total teardown and is not for the faint of heart. Besides if you really want to get into first while moving just float the gears.
Old Mar 8, 2019 | 01:58 PM
Kapusta's Avatar
Kapusta
Old Mar 9, 2019 | 07:23 AM
EPNCSU2006's Avatar
EPNCSU2006
If the slave cylinder has a leak and potentially you aren't getting full release, it can make it harder to get into gear as well. As short as first gear is in the ZF, it's going to be difficult to downshift into first no matter what. It may have more to do with axle gear ratio, but I only use first when starting from a dead stop with a load.
Maybe start by fixing the hydraulic system and see if that changes anything in regards to downshifting into first gear.
Old Mar 9, 2019 | 08:57 AM
Exwhyze's Avatar
Exwhyze
My dad swore up and down when I was learnin to drive 15 years ago that downshifting into first was a surefire way to grenade your transmission, then we went cruising around and he showed me that basically you gotta give er some rpms for 1st gear to slide in. My thinking is that by forcing something you took a bite out of that 1st gear synchro.
For what it's worth, i forced an old subaru into second gear and sheared a tooth right off the gear, which then rendered the vehicle entirely undrive-able. Literally locked up the whole geartrain. I'm happy your rig still moves! Good luck!
Old Mar 9, 2019 | 09:42 AM
Kapusta's Avatar
Kapusta
kupiec20
18
Nov 22, 2013 10:09 PM
Lex Dayton
Apr 6, 2012 08:01 PM
sean23johnson
Jul 13, 2011 09:21 PM
robin22m
Mar 24, 2009 04:31 AM
MOLLYMOJO
1983 - 2012 Ranger & B-Series
Mar 16, 2002 12:27 PM
