Torque Pro app
Old Mar 11, 2019 | 09:22 PM
Rod Jr.'s Avatar
Rod Jr.
Yes I did re-install the app but no different.
Old Mar 11, 2019 | 10:34 PM
Strokinmy3rd's Avatar
Strokinmy3rd
Just to chime in here** I personally recommend the bafx adapter! I ordered mine straight from their website after reading about how there are some counterfeits going around.. BAFX.COM
Old Mar 11, 2019 | 11:32 PM
Rod Jr.'s Avatar
Rod Jr.
Just received mine tonight, will try out tomorrow. I will use the bluetooth version of BASF while my son also got the wifi version, we both have ios devices and android.
Old Mar 12, 2019 | 12:20 PM
Rod Jr.'s Avatar
Rod Jr.
The BASF bluetooth sender fixed my problems, thanks to all of you that helped.
Old Mar 12, 2019 | 12:31 PM
diesel_dan's Avatar
diesel_dan
Good to hear..
Old Mar 12, 2019 | 03:19 PM
SmackDaddy's Avatar
SmackDaddy
I have one coming in tomorrow. Is it faster than the ELM327 clear blue one?
Old Mar 12, 2019 | 06:37 PM
Rod Jr.'s Avatar
Rod Jr.
Only issue is that the Delta T pid is not reading correctly, I used this: (([221310]*1.8)+32)-(([05]*1.8)+32)
Old Mar 12, 2019 | 07:56 PM
F350 1990's Avatar
F350 1990
Been running OBDLink MX+ for about six months --- hasn't lost signal yet................iOS and Android compatible, plus they tossed in the entire add-on / enhanced library since I was a prior customer.
Old Mar 13, 2019 | 12:22 PM
Rod Jr.'s Avatar
Rod Jr.
I have tried the delta temp pid on two different android devices, still cannot get it to work.
Old Mar 13, 2019 | 03:17 PM
diesel_dan's Avatar
diesel_dan
Edit: not sure on the calculation being wrong for that. Here's my old thread that has that and more in it:
https://www.ford-trucks.com/forums/1...ew-gauges.html
Good luck!
Scott
Here's just the Calc part: (([221310]*1.8)+32)-(([05]*1.8)+32) And it looks like you have the same - did you follow the rest of the instructions for setting that up?
Old Mar 13, 2019 | 03:36 PM
Rod Jr.'s Avatar
Rod Jr.
I followed your post #1 from 5-18-14: Leave ODBII PID blank
Long Name: Delta Temp (or whatever floats your boat)
Short Name: C/O Delta (or O/C Delta, what you want to see in the gauge)
Minimum: 0.0
Maximum: 30.0
Scale factor: x1
Unit Type Deg F
Equation: (([221310]*1.8)+32)-(([05]*1.8)+32) NOTE: This is now the CORRECTED formula
Old Mar 13, 2019 | 06:15 PM
diesel_dan's Avatar
diesel_dan
Sorry Rod, it should work, been racking my brain for some odd ball think like a config setting, but I got nutin'... Only thing I can think of is to post a Q on the Torque Forum, the fellow that wrote Torque will answer sometimes, maybe they will have some ideas - lots of folks creating their own custom gauges...
Scott
Old Mar 13, 2019 | 06:24 PM
  #28
Rod Jr.'s Avatar
Rod Jr.
I have visited that site, seems their isn't much activity there. I will try one more Samsung tablet this weekend to see if any change, Again thanks for your help.
FrankNBeans
Jan 25, 2017 02:56 PM
HKusp
25
Feb 13, 2016 11:02 PM
BGLeRoy
Modular V10 (6.8l)
May 1, 2015 10:34 PM
Bonanza35
Sep 15, 2014 04:25 PM
BobbyDiesel71
Oct 7, 2008 09:10 PM
