MAF conversion problems
That being said, please clarify which MAF meter you used and any other mods, such as cam and headers "
OK, new thread, all the gory details.
I started simple; just a straight conversion using ALMOST all stock configuration. The engine had been running an aftermarket set of 1.5" tubular headers for about 30 years, and a few years ago I installed a set of 1.7 Cobra rockers. This was all running on the original SD computer. I want to build a new engine to replace the 30+ year old stock engine, with enhancements like a 331 displacement, AFR 165 heads, GT40 intake, and some yet-to-be determined cam. So based on all I've read, the stock computer can not handle these changes, and most of the reprogrammers only work with the MAF computers, such as the A9L. I got the A9L and matching MAF metere from a dismantler many years ago, and did the conversion recently following the instructions found on the net.
Right after the conversion, my first problem was that the engine would not stay running for more than about a second after starting. After checking all the wiring, I found out that if I pulled the MAF signal wire from the meter, the engine would run after starting. Obviously, I couldn't run that way, so there was still a problem somewhere.
The self-test indicated low MAF voltage, and I traced that to the blown caps that everyone recommended replacing. After I replaced the caps, the low MAF voltage error code went away, but the engine still would not run for more than a second after starting. Again, pulling the MAF signal wire allowed it to run.
Eventually, I got another A9L and matching MAF meter to test with. This one allowed the engine to run, with the MAF signal connected. So the first thought is something was wrong with my first A9L computer. Since the cold engine was idling badly, it stalled while I was checking the meter.
That's when I noticed crackling sounds, and smoke coming out of the bundle of wires going into the firewall. I pulled the battery cable off as fast as I could, and tried to find where the smoke was coming from. It turned out to be from one of the wires from one of the AIR solenoids. It was frayed, and may have shorted out to its +12 wire. So I fixed that, and tested all the other wires from the EEC connector to where they should go for continuity using a test light.
After verifying there were no more shorts, and all the fusible links were still fusing, I put it all back together, but this time I installed my old A9L computer. It ran the engine as well. So I'm guessing that the shorted AIR wire must have messed up its signals or something.
Re-running the self tests still showed code 67, the NSS error, but nothing else. On my 87 car, the HEGO harness only has the wires for the sensors, and nothing for the transmission, as the later models do, so I'll have to make some kind of jumper if I want to simulate the NSS switch. As I mentioned in the other post, the engine seems to idle high while coasting, and drops to normal when I come to a full stop, which indicates that it's seeing the VSS signal that I wired in.
So for now, the only symptom left is the poor cold idling, and the occasional idling weirdness while driving. Would the lack of the NSS cause this? I notice in the wiring diagrams that the NSS is connected in parallel with the clutch switch. I haven't checked to see if that wire is connected to pin 30, but if they are in parallel, do I even need a NSS?
As for the poor cold idle, I'm working through that myself now too. Mine sometimes dies instantly when cold. See my setup below. My belief is that with mods like outs, the engine in not getting enough fuel on startup (cold engine required a lot more fuel to run, contributor being poor atomization), or problem with the MAF transfer. I picked up a Quarterhorse and associated software which is allowing me to make these adjustments. Its tough.
I think the other schools of thought would be to monkey with the idle set screw, fuel pressure, ect, but IMO your just tricking the ECU into doing what you want. Something to consider is you MAF setup; is it the same meter in the same housing with the same intake/airbox that is paired with the ECU? Even clocking the MAF meter in the intake can change the readout.
If I swap my SD computer back in, it would run normally; smooth idle at cold start. So I'm guessing it's not reading the MAF sensor correctly when cold. I did check to see if it was actually reading by pulling the signal wire while the engine is running, and the engine does make a stumble. Maybe I need some kind of a tuner device to correct this. But this is a pretty stock engine, with stock heads, cam, and intake, so I thought it should be operating in the range that a stock EEC should be able to handle.
In addition, wires are added for the fuel pressure relay sensor, the VSS, and maybe some changes for the transmission NSS. I added the first 2, and the way the A9L behaves tells me they're working. I verified that the positions for those pins on the SD computer are not connected to anything, so it was safe to leave them there when I swapped the SD computer back in. I also swapped back the AIR control wires when I did that to make sure they still worked.
I could not do the NSS mod (pin 30), as the HEGO harness in my car has none of the wires for anything going to the transmission, just the wires for the HEGO sensors, and I think the oil level sensor.
Thanks for the pinouts; I see a lot of pictures of the MAF Mustang computers, but almost none of the SD computers.
Also, on cold start, how cold is it outside, and do you get that 1,200 rpm surge when it fires? Could you describe the rough idle? Low, stumble, surging?
I'll try to add that second VSS wire this weekend if I have time. (still working on the 69; hoping to complete the head/intake install)
However, I did make connectivity tests between the power and ground pins on the EEC connector and where those wires tap into the car's power and ground points, and they're solid. I used a high powered LED of about 6 watts, so it draws at least 1/2 amp, so it's more effective than just using an ohm meter.
Still struggling with very poor cold idle. It's quite obvious that it's running too lean when the cold engine is just started. If I push the throttle enough to keep the engine running for about a minute, it will stay running, though poorly. For the first few minutes of driving, it is definitely too lean, as it will buck, surge, backfire, and stumble, if I'm not careful with how to rev up the engine when trying to get the car going. Once the engine warms up, it runs much better, though idling is still a bit rough.
Does any EEC experts know if the program needs some kind of a signal to tell it to run in a special mode when first started? I checked the ECT signal, and it seems to be working. I'm not sure if the MAF signal is correct. Does anyone know what are the range of values its output supposed to be? I can try to wire a voltmeter to it to see what it shows when cold or hot.
