Just bought an Excursion; Help me upgrade it!
Old Mar 17, 2019 | 08:15 AM
  #46
05XCRSN's Avatar
05XCRSN
Cyclone Bomb
18 inches from the cyclone bomb was no match for the EX. the ice that was left over 2 days later had me stuck in my own driveway with a trailer on the hitch!
what's up with the 4WD? I get stuck, manually lock the hubs, and nothing happens. 4WD doesn't engage when your spinning wheels? Only after you roll a few feet?
Old Mar 17, 2019 | 09:29 AM
  #47
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Originally Posted by mailseth
I’m about to put the new springs on, remove the lift blocks, and keep the factory blocks, but I realized that I might need some axel shims to keep the pinion at the correct angle. Is this something I should be worrying about with a 4” lift on something as big as an Excursion? 2* shims? Anything I should watch out for? I’m getting conflicting info from other threads.
yes you need a 2* shim between the axle and the springs to correct the driveline to pinion shaft angle.
these are the ones you want. You may also need a longer spring center pin since these must be bolted into the spring pack.
( I had to drill the hole in mine larger because my sprints use a larger center pin )
https://www.wfoconcepts.com/pr/2-Deg...3225/4384/4391
Post a pic of your rear driveline showing the transfer case end.
there are 2 types of drive shafts, the 2* shim is for the style that uses a single ujoint at both ends.
Old Mar 18, 2019 | 01:10 AM
  #48
mailseth's Avatar
mailseth
Here’s the transfer case end.
Old Mar 18, 2019 | 09:34 AM
  #49
pirate4x4_camo
FTE Remembers
2* shim should correct your pinion to within .05* of parallel which is ideal.
68camaro327
Aug 30, 2018 08:49 AM
dmp
Michigan Chapter
75
Feb 18, 2015 07:49 AM
FordGuy0131
Feb 20, 2010 07:37 PM
admiralturbo
Bronco II
Oct 6, 2004 11:10 PM
garymake
Nov 17, 2003 03:30 PM
