Manual swap
Old Mar 4, 2019 | 09:37 PM
Cory Pittman's Avatar
Cory Pittman
Manual swap
I have a 95 f350 7.3 TD dually and am wanting to do a manual swap to a zf5 will o need to change my ecm in order to do so?
Old Mar 5, 2019 | 08:30 AM
farmert's Avatar
farmert
No, you can leave the transmission range selector , from the auto, hooked to the truck's wiring harness, and you will be able to drive the truck. The cruise control will not work if you go this route.
Old Mar 5, 2019 | 05:54 PM
fordpride's Avatar
fordpride
IMO the best way to do this is buy a parts truck, swap everything over and sell the rest.
Old Mar 6, 2019 | 08:12 AM
Bob_T's Avatar
Bob_T
Parts truck is definitely the way to go. I pieced my parts together and it sure would nave been nice to have a parts truck. You can keep the auto ECM if you want to but I’ve heard that the auto programming makes the throttle real twitchy when starting out. I changed mine to manual ECM so I never ran the manual trans with the auto ECM. I think you can also get a PHP Hydra chip with manual tunes for the auto ECM.
Pretty sure that the cruise control circuit is independent of the ECM, you just have to swap some wires around on the harness. I kept the auto harness and cut off the unnecessary wires. I probably spent more time reading and studying “swap” threads than I spent on the actual work.
Old Mar 12, 2019 | 08:28 AM
DIYMechanic's Avatar
DIYMechanic
You have three options:
1- Leave the TRS in the truck in the N or P position and use your Auto PCM
2- Make a wiring change under the dash (essentially, just adding a jumper), eliminate the TRS, and keep your Auto PCM
3- Swap in a PCM from a manual truck.
Any one of the three will work just fine and drive normally.
Red454sedgwick
Nov 20, 2014 09:17 PM
fordi3s3l
Apr 12, 2014 09:06 AM
raccol
2004 - 2008 F150
Sep 16, 2006 12:50 PM
tagkat
May 28, 2003 01:15 PM
