Oil & Lubrication
Additive
Old Sep 30, 2003 | 03:26 PM
wolson's Avatar
wolson
Additive
I am planning to change the transmission fluid in a 97 ford F-150 with an auto 4R70W transmission. The truck has 85,000 miles should I add any type of additive to help extend the life of the trany?
Old Sep 30, 2003 | 05:31 PM
DCurtiss's Avatar
DCurtiss
If you use Mercon V, you probably do not need any additives. With the basic Mercon, then you might want to add something. When I did my 96 F150, I added Lube Guard a month or so after I did the Mercon ATF change. I cannot prove it one way or the other, but it seemed to smooth out the shifts a little.
