Sponsored by: Real Truck
5.4 2v Coil Pack
Old Mar 2, 2019 | 11:51 AM
idealtrucks's Avatar
idealtrucks
5.4 2v Coil Pack
My 03 5.4 has developed a miss under load recently. I don't know which coil it is, but I assume that it is. Spark plugs replaced probably 5K miles ago. I tow a 7k pound camper with this truck. Truck has 130K miles
I have a few questions: Should I track down which coil is bad and change just it? Or, with the miles on it, should I go ahead and change all 8?
Next question: What brand coils should I go with? Looks like Motorcraft is about $35 a piece. THere are sets of 8 all over ebay and amazon for about $25-$30. Ebay has a set of 8 MSD brand street fire for $165 or MSD Blaster for about $200.
I'm not sure which brand to go with. Any experience with any of these?
Old Mar 2, 2019 | 11:55 AM
Fefanatic's Avatar
Fefanatic
You should be able to scan the engine and determine which cylinder is misfiring. If you do that then swap that coil with a known good cylinder and see if the problem moves to the cylinder with the suspected bad coil If so replace that coil. FWIW, it's most likely the coil boot is bad and not the coil. Once you determine it is the coil you might swap the boot with another known good coil boot and see if the problem moves again. If so then just get a set of boots and save yourself a bunch a money.
Old Mar 2, 2019 | 02:01 PM
SuperDutyScaler's Avatar
SuperDutyScaler
My 2004 f350 with the 2valve 5.4 just hit 170k last night. I have ALL ORIGINAL COP's still...I do change the spark plugs and the boots/springs ever 30k since new. Motorcraft spark plugs with silver nerverseize and ACDelco boots (acdelco were original equipment)
Old Mar 2, 2019 | 02:15 PM
Sam I Am's Avatar
Sam I Am
It is vastly less expensive to buy a cheapie code reader and scan the vehicle than to throw money at it parts swapping.
By far the most useful thing I have bought to work on computer controlled cars is an OBD2 adapter and Torque Pro app.
Old Mar 2, 2019 | 02:59 PM
Fefanatic's Avatar
Fefanatic
FWIW, I have done a few engines with two piece spark plugs and I have never been able to get all 8 out without leaving at least 3 in the holes. I'm getting good at getting them out now. I have tried all the tricks like cracking them loose and letting penetrating oil soak for a day or so and still they break. Breaking the plugs loose is what generally causes the pieces to stay in the head. Getting the plug loose at the threads hasn't been the issue, it's the carbon buildup on the lower part of the shield sticking out in the chamber hole that causes the breakage. No amount of silver or copper coat can prevent that carbon build up and stop the breakage. The best thing is to change those plugs every 30-50k miles to avoid that carbonbuild up. If the engine is consuming oil then change them sooner to avoid that buildup.
Old Mar 2, 2019 | 03:17 PM
Bently_Coop's Avatar
Bently_Coop
Most scanner's should pick up which cylinder is failing. I ran a Scanguage 2 prior to my SCT Livewire that I have now. Both pick up the codes when failed even though a Check Engine light may not illuminate.
I recommend using Denso COP's as they are the manufacturer of Motorcraft COP's. I've posted pictures showing such after another Member pointed it out.
Pick up two COP's, swap the one out and stick the other in the glovebox.
Old Mar 2, 2019 | 03:24 PM
SuperDutyScaler
The OP has a 2valve 5.4 so it has one piece spark plugs. Telling him he has two piece plugs and that nerverseize won't help is is just bad I formation.
OP buy a cheap scanner or have a shop pull the code for you. Swap the coil to another plug and see if that miss follows, if it does it's the cop boot OR the cop itself. If it stays then it's the spark plug OR the injector on that cylinder OR a wire issue at the plug or inside the harness
Your spark plugs should be torqued to 18ftlbs and use a light coat of silver high temp never seize on the threads.
Also use a air nozzle with an extension to blow the plug hole out, I do this before I remove the old plug and then spray brake clean down the hole and put a shop towel over it and blow it dry again (two times for each hole I'm a little OCD) then blow hole out again before I install new plug
Old Mar 2, 2019 | 09:32 PM
R&T Babich's Avatar
R&T Babich
You are working with 3v motors if you have the notorious 2 piece OEM plugs.
Our 2v motors use the old style plugs.
Once you get the OEM 2 piece plugs out the replacement plugs have been upgraded to 1 piece so it shouldn't be an issue the next time around.
Old Mar 2, 2019 | 09:37 PM
R&T Babich's Avatar
R&T Babich
I have a few questions: Should I track down which coil is bad and change just it? ....
The coils are probably just fine.
If the boots are OEM with 130k I would change all the boots, Denso 671-0001, Rock Auto, $32 for 10 boots.
Old Mar 2, 2019 | 09:39 PM
ford390gashog's Avatar
ford390gashog
Just curious what brand of spark plug was used?
Old Mar 3, 2019 | 10:14 AM
Fefanatic's Avatar
Fefanatic
They still look like 2 piece to me and the way the new plugs look they will still twist and break if allowed to get carbon build up. it's the initial twist when trying to remove them that breaks them. That's why I don't believe any penetrating fluid works well since the damage is done when you crack them loose to let penetrating oil past threads.
Edit to add: I see Champion does make a one piece spark plug but I would never put a Champion plug in a customer vehicle. In fact I won't use them in a lawnmower.
Old Mar 3, 2019 | 01:52 PM
idealtrucks
The replacement plugs were motorcraft. I'm going to stop by local shop tomorrow and let them see which cylinder it is. I'll put it and see how the boot looks.
Old Mar 3, 2019 | 02:23 PM
Fefanatic's Avatar
Fefanatic
Sometimes you can see the spark track in the boot but that is more rare than reality. Like I suggested, move the suspect coil to a different cylinder and see if the problem moves with it. If so then replace that boot. If that stops your problem then replace the rest of the boots on the other coils. If it didn't stop the problem then replace the coil. There's no sense in spending more dollars than you have to when you can make the correct diagnosis and make the proper repairs.
Old Mar 3, 2019 | 02:43 PM
idealtrucks
Yes, that does make sense. I'll have to see if I can get the shop to scan it for me a couple of times. I don't have a scanner
Old Mar 3, 2019 | 08:09 PM
Sam I Am's Avatar
Sam I Am
https://play.google.com/store/apps/d...g.prowl.torque
https://torque-bhp.com/wiki/Bluetooth_Adapters
