Mustang 2 clip
OK guys I am on the case. Don't think the 800 number work from over here, but that's not a problem. I think I am learning fast...I have just emailed Heidts with some questions. To the poster earlier that mentioned it is just a truck anyway...I realise that, but my truck is just pretty awful to drive as it is at present.I am sure I can improve it with the right bits.
Suffolkman
Suffolkman
Hey Suffolkman,
I was also surprised at how truck like it drove as well. It's not like the smooth ride
of a Jaguar.. not even close. Our ride improved with a good alignment, good tires,
a sway bar, etc. Your front end looks to have been professionally installed.. the welds look nice,
the frame has been boxed in, etc. The trucks also ride a lot better with some load in the back.
Do you have radials?
I was also expecting a really smooth ride … like a new truck. That hasn't been my experience.
Good luck on your ride improvement quest - keep us posted on your progress.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Suffolkman
I just re-read the first few posts again. So you had 350 lb/in springs and changed to 400? Do you know what the ride was like with 350? If they were the same length your ride height would hardly change. Longer springs would add more pre-tension and increase ride height. So what was the change in length? How much do the springs compress when you sit it on the ground compared to jacked up?
Looking at the pictures your lower control arms arent parallel to the ground. So you could order higher rate springs. So let's say you have 350 on now you could go with 400 or 450 lb. But keep in mind that could result in even harsher ride depending on which springs you order. Adding a better quality shock would help with this.
As for what kit you have that's hard to tell because there are some many company's who are making the kits now. looking at the upper spring perches it actually looks like a universal kits. I ordered mine of Ebay and it's pretty much identical to heints but it's not a heints. I dont have my front end on yet so my controls arms are out the opposite direction as yours.
Received 4,132 Likes
on
#29
I think I am learning slowly over the last couple of days. I think what I need to do is strip the suspension down and find out what springs I have, Maybe the weight might be stamped on the springs ?. I am also thinking that I may need slightly heavier springs. My present one maybe bottoming out on some of the potholes on our country lanes. If I got longer springs, wouldn't I need longer shox ?. Thanks to all again for your input.
Suffolkman
Suffolkman
#30
on
No your shocks will be fine , longer springs won't change the amount of travel only the ride height . When you say harsh ride do you feel the suspension is bottoming out or too stiff ? If it is bottoming then you need stiffer " more lb spring " if it is just not using the travel then you need a lighter " less lb spring " .
