What do I need?
Old Mar 6, 2019 | 07:13 AM
Olds64's Avatar
Olds64
Originally Posted by Charmalu
Raymond, you are correct.
x2
I just took the starter bolt to the hardware store to match it to an 8" bolt. I don't think reaching that top bolt is "EASY" though. Maybe if you're a circus acrobat.
Old Mar 6, 2019 | 09:29 AM
RaymondIV's Avatar
RaymondIV
Raymond, you are correct. I said 10mm, that was the only socket I found that fit the head of the bolts.
A 10mm 12pt.
I have mostly metric tools, since since 1981 I bought a Datsun Diesel PU, and then from 97 on...I have
a bunch of Mercedes Diesels from the 80`s time period. Still have the Datsun, and a Nissan Diesel PU.
Since I bought the Ford, I have been slowly accumulating SAE tools.
Charlie
Charlie, I'm unfortunately just the complete opposite, I've worked on American iron for a living all my so-called adult life and the recent influx of metric stuff drives me nuts including two of our own vehicles. I can look at a SAE standard US bolt from 20 feet away and grab the right size wrench. When it comes to metric, all I know is if it's teeny it's 10MM.
Old Mar 12, 2019 | 07:23 PM
Skagewa's Avatar
Skagewa
Alright everyone, I changed my batteries and the batteries weren't the problem. Same issue is happening. I tried twisting my fuel filter out and it wouldn't budge, daylight is almost out so I gave up and tried to crank it after I replaced my batteries. My cables are in decent condition I would say after a good cleaning. I .Starting to think jelled fuel could be the main issue. I doubt it's my starter since it's relatively new. How would I be able to fix the jello problem?
Old Mar 13, 2019 | 08:14 AM
Olds64's Avatar
Olds64
How cold is it there in CO right now? It was in the 30s a week or 2 ago in OK and my truck would start right up with 8-10 seconds of manual GPs. Are your glowplugs in good condition? I use Lucas fuel treatment every time I put fuel in the truck and I've never had a gelling problem. Then again, it isn't very cold in OK.
Old Mar 13, 2019 | 10:37 AM
Skagewa's Avatar
Skagewa
My plugs should also be in good condition. As I said earlier, I crank it and then it slows down like it's dying. Would it be a possibility that I have gel in my fuel filter? It's been warming up but again it's going to snow. Fml 🌨️🌨️🌨️.
Old Mar 13, 2019 | 09:02 PM
DarkOverCast's Avatar
DarkOverCast
A little off topic but our zd-1's are 6 volt glow plugs with 12 volts running to them so they start faster. A 87 6.9 or 7.3 that uses the zd-9's will take a little longer as they're actually 12v sticks.
Back on topic, I don't see how gelled fuel would cause it to crank fast then slow. Sounds like a possibility that the starters weak..either that or the batteries which you stated you tested.
I'd try disconnecting the glow plugs and giving it a sniff of ether and see if it starts and stays running to rule out fuel.
Old Mar 13, 2019 | 09:11 PM
Skagewa's Avatar
Skagewa
I just replaced my batteries the other day. I was contemplating on using ether. I've only had to use it once and I know it's bad for the engine so I try to use it only for emergencies
Old Mar 14, 2019 | 03:52 AM
DarkOverCast
Do you have another vehicle you could hook up with jumper cables or one of those battery chargers with engine start assist?
If it cranks over fine with the extra juice that would point to your connections or starter
Ether in itself isn't dangerous, it's the idiot behind most cans spraying too much. Just a wiff is all it takes
Old Mar 14, 2019 | 04:01 AM
Skagewa's Avatar
Skagewa
I called AAA last week and he tried to jump me and it didn't work .I tried a quick jump starter and that didn't work either.
Old Mar 14, 2019 | 07:18 AM
Olds64's Avatar
Olds64
You mentioned earlier that your fuel filter was frozen pretty good on the filter housing. Did you ever get it removed to check the fuel level for air intrusion? Even if you don't replace the filter, filling it with ATF will clear out your injectors and IP once you get it started.
Old Mar 14, 2019 | 12:50 PM
Skagewa's Avatar
Skagewa
I tried getting it off but the filter started bending. I'm not sure what I should do other than call someone to get it off since I don't want to break anything
Old Mar 14, 2019 | 12:59 PM
Olds64's Avatar
Olds64
Try to use a strap wrench to remove the fuel filter. Apparently, it was tightened by a gorilla.
Old Mar 14, 2019 | 01:02 PM
  #28
Skagewa's Avatar
Skagewa
Sadly it was I who tightened it 😦. I just have terrible luck when it comes to winter. I'm moving next year so I don't have to deal with it anymore.
Old Mar 15, 2019 | 12:01 AM
  #29
DarkOverCast
I would replace the starter or rebuild it yourself. If these motors don't spin over fast enough they just flat out won't start. Especially when its cold
Old Mar 16, 2019 | 08:52 PM
  #30
Charmalu's Avatar
Charmalu
I just read through this thread again.
Are you close to 110V out let? If so grab a HF Heat Gun and play it on the filter and fuel lines for a few min to
thaw out things.
Then remove the Air Filter lid and element, shove the Heat gun down the intake for a minute or so, and she
should kick right over.
Be sure the wires are out of the way of moving parts. I let the gun run as I start the engine.
Charlie
