Leaf springs sagging, solutions?
Old Feb 27, 2019 | 11:25 AM
Bluebronco85's Avatar
Bluebronco85
Old Feb 27, 2019 | 11:28 AM
Bluebronco85
Originally Posted by SRBF150
That's the rub with leveling a truck made for towing. IMO, if you tow, leave the leveling kits off and for that matter, lift kits in general. Just my .02.
the lift was on when I got it but I probably would have ended up putting one on anyway. My 03 250 was a 3” lift I never got the kind of sag out of it like this one. That’s why I feel that the springs are soft.
Old Feb 27, 2019 | 11:32 AM
SRBF150's Avatar
SRBF150
Gotcha. The front being up, means that the rear has to be higher and maintain the rake that was set from the factory which can create issues with towing height, but you know this already. The rear springs could be soft and it looks like there are some options other than replacement like the helwig setup. That said, a call to SD springs or other vendor could probably help once they know the spring you have now, what weights you tow and then provide a recommendation for a stiffer setup. I still like having bags for some flexibility in towing weights and keeping a softer ride unloaded so, give that some thought and research too.
Old Feb 27, 2019 | 12:06 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Your springs are not “soft” your bed is just heavy.
one way or another you need to increase your spring rate to accomadate the additional payload of the bed.
since your bed is now a permanent payload you could get a new spring with the spring rate to accomadate the new curb weight. Or get an adjustable air spring that will accomadate the new curb weight plus and additional payload.
Old Feb 27, 2019 | 12:21 PM
Dan V's Avatar
Dan V
Originally Posted by Bluebronco85
You are "V" code front which equals 2230lbs each and the rears are "B" which I think are 3000lbs each.
Old Feb 27, 2019 | 12:31 PM
Walleye Hunter's Avatar
Walleye Hunter
ATS Springs has done quite a few of our guys here right, including me. If you call them and tell them where you're at weight wise and where you want to go they will hook you up with the right setup. I believe that one of our members in AK even had a set shipped up to him.
Old Feb 27, 2019 | 12:38 PM
pirate4x4_camo
Close
V have a spring rate of 430 lbs inch with a capacity of 2600 lbs
B have a spring rate of 330 primary, 830 overload , 1200 combined with a capacity of 3000
Old Feb 27, 2019 | 01:04 PM
Dan V's Avatar
Dan V
Originally Posted by pirate4x4_camo
Close
I had the same rears and went with the 43-1263 from ATS...3300lbs each.
Old Feb 28, 2019 | 08:50 AM
BWST's Avatar
BWST
Got Data?
Originally Posted by arto_wa
"...Here is my (dually) setup with factory stock springs + torklift stable loads & hellwig add-on overloads:"
X2 on the torkllift stable load bump stop extensions, to take advantage of the factory overload spring that's already there. I used them and 50psi in Firestone ride rite airbags to level my truck with the 5000lb camper and the boat on the superhitch. Rancho 9000 adjustable shocks helped here too, though I'd probably go Bilsteins next time and skip the adjustability.
Old Feb 28, 2019 | 03:39 PM
brian42's Avatar
brian42
Veteran: Navy
Talk to Junior. He's the one that helped me figure out what I needed.
Old Feb 28, 2019 | 05:23 PM
nossliw's Avatar
nossliw
Bags period!
Old Feb 28, 2019 | 08:58 PM
Tinstar1's Avatar
Tinstar1
If your handy with a wrench go grab a rear leaf pack out of a 1 ton from a salvage yard or CL. Take the top leaf out, cut off the eye's and add it just under your top main leaf. You will be surprised at how much extra carrying capacity that will give you plus won't hurt your ride quality. You will have extra leafs to further adjust ride height and or load carrying ability.
Looks like you have room to add at least 1 leaf with your U-bolts. You will need 2 longer center bolts for the leaf packs as well. I have added more leaves like this over the years than I can count.
You can also add/adjust your overload pack if needed.
Old Mar 1, 2019 | 08:15 AM
  #28
Bluebronco85
that sounds like a plan. I think I saw that ATS sells just a top leaf on their site that I want to say was around $80. Thanks
Old Mar 1, 2019 | 11:50 AM
  #29
brian42's Avatar
brian42
Veteran: Navy
If you are planning on adding any leaves it wouldn't be an issue as you can buy longer u-bolts from ATS.
Personally I don't re-use TTY items.
Peavey1986
Apr 21, 2015 12:36 AM
chruby99
Oct 3, 2014 03:23 PM
SaddleBronc
57
Feb 21, 2014 05:43 PM
BigBlueIron
Apr 3, 2013 07:50 PM
Jmudder79
Offroad & 4x4
21
Dec 30, 2007 09:38 AM
