Different Rims
Old Feb 25, 2019 | 09:59 PM
Waco-kid's Avatar
Waco-kid
Different Rims
Quick Question,
I don't like the 20"s on my 2018 stx, I would like to trade them off for some 17's or 18's. I will go with oem wheels; but when looking on craigslist or marketplace I see that people either remove the tpms or they still have it. If I buy a set that still has tpms will it talk to my truck or do I have to move the sensors from my current rims so that it will keep in contact with the truck?
Thanks.
Old Feb 25, 2019 | 11:08 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
You can reprogram your truck to different TPMS sensors. If you don't want the trouble of doing that then you can move the TPMS from old rims to new.
Old Feb 26, 2019 | 05:54 AM
IndyDog's Avatar
IndyDog
Why don't you like the rims? Most move from 17's 18's to the 20's & 22's when they switch.
Old Feb 26, 2019 | 09:26 AM
CR172's Avatar
CR172
I just switched my non-peeling 18" PVD wheels for 20" Platinum wheels and installed new OEM tpms sensors I got off fleabay . No programming, nothing. They work perfectly without doing a thing.
Old Feb 26, 2019 | 11:03 AM
scott91370's Avatar
scott91370
I also switched form 20 to 18. It's a truck that is used off-road a bit and I wanted the sidewall. And I'm not a huge fan of low sidewalls on a truck either.
Old Feb 26, 2019 | 11:18 AM
ford390gashog's Avatar
ford390gashog
The only thing I will mention is the load rating of the 20inch wheels is higher so if you have a max tow equipped truck and plan to keep the same axle load rating keep the 20's. Also 35x12.5R20 fit and give plenty of sidewall.
Old Feb 26, 2019 | 11:41 AM
CR172's Avatar
CR172
Tires are XL rated and have plenty of sidewall for me. It's a highway queen.
Old Feb 26, 2019 | 07:24 PM
Waco-kid's Avatar
Waco-kid
Thanks for the replys. It sounds like whenever I find a set that I'll probably try to move my tpms over. As for keeping the 20's, I just have never been a fan of the larger rims.
Old Feb 26, 2019 | 10:06 PM
idrive's Avatar
idrive
Originally Posted by Waco-kid
Quick Question,
Thanks.
I didn't see it mentioned that the 2015+ was the last sensor frequ. change. Everything from 2015 -2019 all use the same sensors. When mounted they should learn themselves after a few miles.
Old Jun 7, 2021 | 09:58 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Not what I run into, I just swapped my 20" rims and tires from my 2015 to 18" rims and tires from a 2017. At first they all read 37psi, I then tried a reset as outlined in the owners manual, didn't work. Now I'm getting the fault code and no reading on any tire. Dealer tells me they're probably different frequencies.
Old Jun 30, 2021 | 03:33 PM
Zzoogg's Avatar
Zzoogg
I switched from 20’s on my STX to oem 17’s. The ride is quite a bit less jarring with the taller side walls.
I swapped over the tpms sensors from the 20’s to the 17’s with no issue. Love the ride.
Old Jun 30, 2021 | 03:39 PM
85e150's Avatar
85e150
I got all excited seeing this as I have a set of 18s in the Marketplace. Then I see Texas and 2018.....
Old Jun 30, 2021 | 04:59 PM
Kingofwylietx's Avatar
Kingofwylietx
I just got new tires on my 20's....but checked all over for a decent set of 18" wheels first.
Too bad you are in Pasadena CA instead of Pasadena TX!
Old Jul 2, 2021 | 12:39 AM
Waco-kid's Avatar
Waco-kid
Just an update from two years ago; I found a set of factory18" rims that I wanted and swapped them out. They were equipped with tpms and I rolled the dice and installed them without swapping the tpms and they talked to my truck within a few revolutions of leaving the tire shop!
Old Jul 3, 2021 | 09:27 AM
JKBrad's Avatar
JKBrad
Thanks for checking back in. Not many people do.
nsboyd1210
WTB - Parts & other
Jul 11, 2016 12:08 PM
bigcrunch
Large Truck
May 23, 2016 08:18 AM
HeaVEEweight
May 23, 2009 05:47 PM
Weevil
Nov 13, 2005 06:36 PM
NaviOn24s
Nov 18, 2004 11:37 PM
