It's so frustrating
Old Feb 25, 2019 | 08:14 PM
TXTrailerdaddy's Avatar
TXTrailerdaddy
It's so frustrating
I'm just so tired of parts that are supposed to just bolt right in, not bolting right in. I was fighting with the hydroboost and couldn't get the rod to the brake pedal to even drop down enough to go on. Looks like the best solution is to cut the eye off the vacuum booster and the one off the hydroboost, thread them and use a coupler.... Wasted 3 days on that so far. I finally just ordered the hydroboost kit from powerbrakeservice.net I wish I would have started there. For $200 more than what I spent pulling a junkyard booster, I could have gotten one with all the brackets and parts.
Next, I bought a champion radiator. Supposed to be a direct bolt in. NOPE. I'm going to have to make some sort of flange since it is too narrow.
Try to put air cleaner on.... NOPE. the HEI distributor messes with it. So change of plans. Guess I'll go with the chrome round filter. NOPE doesn't work either. Guess I need to find a spacer for under the carb to lift it up .
Headman headers. Yeah they didn't go in per the instructions either.
Just need a day when some things fall into place...... probably too much to ask.
Old Feb 25, 2019 | 08:17 PM
adebord's Avatar
adebord
Bolt on fits have got to be the frustration of the life of these old trucks. Seems nothing fits exactly. Hell I think that’s the fun in it sometimes though. Make it yours best you can.
Old Feb 25, 2019 | 08:24 PM
kettle-one's Avatar
kettle-one
These issues arise when you deviate from stock parts. I had to modify my drop in Champion radiator for my GTS. It just goes with the territory and yes i can be frustrating. I find stepping away and thinking it out helps. Sometimes the fix isn't always clear or apparent when your doing the work than it is when you take a step back.
Old Feb 26, 2019 | 04:36 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on all those parts are not stock, so you get to make them fit. Like he said, just take a step back, think it over, regroup and go at it again. Hang in there, you day is not really going that bad is it?
Old Feb 26, 2019 | 04:55 PM
Dave145's Avatar
Dave145
Once you take a truck and start adding custom pieces and aftermarket parts, no, nothing will be "bolt on" to an extent. Aftermarket is aftermarket. Honestly on my '77 I have yet to have an issue with parts not fitting, but that's because it's 100% stock.
Old Feb 27, 2019 | 10:23 AM
DirtyLarry's Avatar
DirtyLarry
I have loads of trouble getting oreillys or autozone parts to fit on my 79. Seems every single suspension and brake parts requires bringing back and swapping for the right one. Which makes 1 day projects sooooo ****ty.
Instead of being able to park the truck, disassemble, reassemble, and drive. It’s disassemble, realize it’s the wrong part, go back up there, get the right one, then maybe get back in time to finish tonight. All the while having to get a ride back into town to do it.
Ooorrrrr disassemble, take your trucks part up there, (which is a crapshoot because your probably gonna have to order it), then go back and put it together (unless you had to order it, in which case it will be the wrong part and have to be sent back and then you’ll wait another day to get it).
So that brake drum you need? Yeah that’s a 3 day ordeal. And it’s gonna be raining when it comes in, the second time.
Old Feb 27, 2019 | 06:43 PM
TXTrailerdaddy
I hear ya Larry. This thing has been kicking my butt. I spent half a day yesterday fabbing a bracket for the radiator. I finally have it finished. I've found the best way to manage this is to just try and accomplish something, each time I work on it. I have to quit planning to "put the radiator in" because that just seems to not happen. Some days are better than others. Today I went and put the cotter pins in the tie rods that I hadn't done. Then I hooked up the driveshaft. Then tightened the transmission motor mounts and cross arm. Those little things add up to a lot. It is still aggravating that when I get a good day to work on it, and I plan to knock something out, that nothing fits, even though it is SUPPOSED to be a direct bolt in. I guess it is because I see the truck coming together, and I'm really not that far from being done, but it's just like I can't quite get there.
Old Feb 28, 2019 | 10:30 AM
EQCMCAT's Avatar
EQCMCAT
TXTrailerdaddy,
I hear you, some days are better than others. Just try to remember, were still alive and able to make a difference. I've done more times than once as Rich suggested, step away, though that been over the last ten years. Before that I went at it regardless of how frustrating the task became. Not anymore, the self imposed stress take it's tool on you and just isn't worth it. My attitude, "it's better than I deserve". Alive, honest, clean living and I feel fortunate, I came home, unlike allot of Brothers in arms that weren't so lucky. Hang in their fellow forum member.
Listen to some good music, like here come that rainy day feeling again by the Fortunes, or I'll be true to you by the Oak Ridge Boys, Charlie Pride, Elvis If I could Dream. Enjoy your Day.
Old Feb 28, 2019 | 12:47 PM
njdevil77's Avatar
njdevil77
I have never found a problem that a lawn chair, some George Straight and a few PBR's couldn't help solve. It took me a week to figure out that the spacer on my carb was overhanging the manifold by a 22nd of a millimeter not letting it run. I went thru everything, problem was I always removed the carb and spacer first and put it back on last........ I timed it by watching the valves open and close and marking the distributor, vacuum lines out the wazoo, fuel filters and pumps. All to be a lousy Edelbrock spacer on an Edelbrock manifold with an Edelbrock carb atop all bought at the same time at the same place from the same person who "knew what they were talking about".. That is when I learned the lawn chair trick. Works like a charm every time.
giffenf
Aug 14, 2018 08:13 PM
Shawn_Laughlin
May 28, 2018 02:46 PM
Drewski 2
93
Sep 7, 2011 08:13 AM
rcav8or
Dec 6, 2007 02:29 PM
Red Ford Truck
Ontario Chapter
Jun 18, 2007 09:16 PM
