No power to ignition switch
Old Feb 24, 2019 | 05:43 PM
Sam Ve's Avatar
Sam Ve
I picked up a 90 F-250 yesterday 4x4 that had been sitting up awhile Was told it was running when parked .
I got some new batteries for it today and went to try to start it the ignition switch was acting and feeling funny.,could get the dash to come on and finally got the glow plugs on but would die when I went to the start position.
Reached my hand on top of the steering column to check the plug and as soon as I touched it the switch fell apart. When that happened it shorted somewhere under there.
Went and got a switch and put it on and now I've got nothing on the switch just nothing at all happens when I turn it..
So I'm assuming I most likely blew a fusible link and did find several next to the passenger side battery.
I've been trying to find a wiring diagram to figure out which one but Google is running me all over the place and half the diagrams you really can't see well enough or it's sending me to the wrong years.
So my question is does anyone know which one feeds the ignition switch without me having to knick all the wires to test for power? Rather not do that.
Thanks for any help you can offer.
Old Feb 25, 2019 | 02:58 AM
DarkOverCast's Avatar
DarkOverCast
Your probably going to be hard pressed to find the wiring diagram.
I always just poke em with a test light on each side, use tape or liquid electrical tape to cover the holes so no condensation can enter and corrode the wire.
Old Feb 25, 2019 | 07:32 AM
Sam Ve's Avatar
Sam Ve
Thanks, guess that's what I'll do. I'll run up to the parts store soon and pick up a good, sharp test light. The test leads on my meter won't go through insulation too blunt . Hope this truck works out,, if the motor is good I think I got a good deal, but if there's any major problems it was a bad deal. I rolled the dice.
Old Feb 25, 2019 | 12:53 PM
Sam Ve's Avatar
Sam Ve
Found it and temporarily jumped until I hear the engine run thanks
sseebart
Dec 3, 2014 05:06 PM
Dr_Barker
Jan 26, 2013 09:41 AM
monk2727
Jul 18, 2011 12:24 PM
MikeSmithFL
Jul 16, 2005 10:19 PM
