Auto column shift arm
Old Feb 24, 2019 | 05:21 PM
Jimmy nz's Avatar
Jimmy nz
I'm assembling an auto column but can't see which way up the lower shift arm goes the diagram seems to have a flat arm where as mine is bent
Old Feb 24, 2019 | 06:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the truck, which type of A/T?
Be aware that whatever info you get, it will be US/Canada related. "Down under" use different parts catalogs, plus y'all drive on the wrong side of the road.
Old Feb 24, 2019 | 07:29 PM
Jimmy nz's Avatar
Jimmy nz
Shift arm
Thanks for the reply ND I found a good photo showing what I needed.my truck is an American so I sit on the left side and drive on the wrong side
Old Feb 25, 2019 | 10:16 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I've got a couple of these NOS. I see at least one more NOS, but a good used one should be fine, too. This is for 1965/66.
C5TZ-7302-B - LEVER ASSY. - TRANSMISSION GEAR SHIFT SELECTOR - 1 each
Chad
Old Feb 25, 2019 | 01:16 PM
ontmerc's Avatar
ontmerc
shifter arm
The 1965-66 arm is a non power steering arm straight. Later p/s arms are bent.Power steering columns are shorter and bent arm will give more room from firewall.
Old Feb 25, 2019 | 08:58 PM
NumberDummy
P/S makes no difference until Ford/Saginaw P/S was introduced in 1969 F100/250 2WD & F350, from serial number D96,001.
daveinva
Nov 30, 2018 04:30 PM
drabina
Oct 24, 2016 04:05 PM
centralNH
Mar 13, 2014 05:02 PM
dawfun
Aug 30, 2010 01:08 AM
markjw
Sep 13, 2006 10:48 AM
