1987 E350 - Vacuum Lines
Old Feb 24, 2019 | 02:37 AM
Roberttheblob's Avatar
Roberttheblob
Hey there,
i just changed the Valve Cover Gaskets on my 87 E350. It's a 460 V8 7.5L with a Hollie Carb.
I was placing everything back together and I’m confused about some of the hoses.
My PCV Valve has two valves - but I think that as long as I’ve owned it (a couple months) it has only had a hose attached to the main valve (bigger valve). Should there be a hose that I should connect to the smaller valve or should I block off the small valve? The small valve is just open.
Also I can’t figure out this line? Where should it be connected.
rhenderson1965
16
Jan 7, 2025 10:14 AM
krazeyelf
Mar 29, 2011 06:20 PM
wolfgang031691
1997 - 2003 F150
Jan 17, 2011 06:03 PM
kadrocker
Mar 17, 2010 11:54 AM
brian1
May 13, 2001 11:15 AM
