pcv valve vacuum line
Old Mar 16, 2010 | 06:27 PM
kadrocker's Avatar
kadrocker
Just to double check to make sure I have it going to the right place....Where does the pcv valve from my passenger side valve cover vacuum line go to? We have it running to the back of my carb. I always thought it was weird, but my friend swears up and down that's where it goes. That's where I've been running it for a year now. Why does it go there?
That sound right to you?
truck specs in sig.
What's the word, guys and gals?
Old Mar 17, 2010 | 10:42 AM
Shane in WI's Avatar
Shane in WI
I am trying to get all the vacuum lines correct on my 302 as well. I don't know if it's right, but my pcv valve wraps around to the back of the carb as well.
Old Mar 17, 2010 | 11:40 AM
kadrocker's Avatar
kadrocker
Phew- that makes me feel a little better!
Old Mar 17, 2010 | 11:54 AM
Furyus1's Avatar
Furyus1
Every one I've ever seen had the PCV line running to the base of the carb. There should be a hose connected to the other valve cover that runs to the air cleaner. I believe the combination of these two things makes up the PCV circuit and provides a path for vapor flow...
b4hntn
1978 - 1996 Big Bronco
21
Oct 9, 2018 03:53 PM
rock15t
Aug 17, 2012 04:47 PM
Fox Fader
1997 - 2003 F150
Nov 19, 2010 10:08 PM
ErrorS
Sep 7, 2007 10:43 PM
2FordTrucks
Apr 26, 2003 07:41 PM
