Another trailer light problem-Wiring Diagram?
Old Feb 23, 2019 | 07:34 PM
johntorg's Avatar
johntorg
4wd Low
On my 2013 F250, my brake lights/turn signals are not working on my trailer. The trailer tail lights and brakes work fine. All the truck lights work fine. When I apply the brakes I only have 3.5V on the 7 pin connector for both Left and right signals. The tail light pin on the truck connector reads 12V and the ground is good. Does anyone have a wiring diagram for the trailer circuits?
Old Mar 1, 2019 | 05:45 PM
wirelessengineer's Avatar
wirelessengineer
I don't have a diagram for you, but I can tell you that your symptoms are consistent with a poor connection (likely corrosion) upstream of the point where you are measuring 3.5v under load. It basically acts as a voltage dropping resistor. I would bet that you measure the full 12v when you have the trailer disconnected.
Old Mar 1, 2019 | 07:58 PM
johntorg's Avatar
johntorg
4wd Low
Thanks, It turned out to be a bad fuse 100. The trailer turn/brake light circuit has 3 fuses and teo relays in it. I also found that fuse 90 was bad. It supplies 12V for charging the trailer battery. I bought a wiring Diagram and am waiting for it to arrive.
4x4pwr
All Things Towing
May 15, 2016 06:42 AM
dezertdirt
Electrical Systems/Wiring
Aug 29, 2012 01:32 AM
bigfooteeeee
Nov 13, 2010 07:32 AM
Glockem45
All Things Towing
41
Nov 12, 2010 05:56 PM
KZooDirt
2004 - 2008 F150
Aug 15, 2006 09:00 PM
