Ignition, no spark
Old Jan 5, 2001 | 09:19 AM
tmcalavy's Avatar
tmcalavy
Ignition, no spark
Old Jun 15, 2001 | 05:24 PM
mantta's Avatar
mantta
Ignition, no spark
1987 Ford van, 4.9 engine. I have replaced the ignition coil, the ignition module on the distributer and still have no spark. There is power to the coil when the ignition is turned on. I suspect maybe the pickup coil in the distributer or the ECM, any suggestions out there? Any help would really be appreciated.
Old Jun 16, 2001 | 09:57 AM
jakegypsum's Avatar
jakegypsum
Ignition, no spark
I does sound like the pickup coil could be the problem since you replaced the other components. Also, check your wiring. There could be a chaffed cut in the line or it could be shorting on the block somewhere. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Jun 17, 2001 | 08:29 PM
nitro94's Avatar
nitro94
Ignition, no spark
The pickup coil is nothing more than a wire wound coil so it can be tested with an ohm meter. Usually around 600 to 900 ohms across the 2 terminals that are parallel to each other in the connector going to the dist. Connector disconnected.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
