1961-66 Window Regulator Hardware
Old Feb 22, 2019 | 02:09 PM
Krugerand's Avatar
Krugerand
Does anyone know where to get these screws for a 1961-66 F100? I think the hardware # is 50698-S8.
Old Feb 22, 2019 | 02:27 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Even in the 1975 MPC that * means improvise or procure locally, so they were not available at that time. I've never found any NOS. There is another number they used which was 356782-S
https://www.ebay.com/sch/i.html?_odkw=42868-S&_sop=12&_fspt=1&_mPrRngCbx=1&_osacat=0&_from=R40 &_trksid=m570.l1313&_nkw=356782-S&_sacat=0&LH_TitleDesc=1
Bulk3
You can click on the two links above for examples of reproductions of that part. But, they are only close. They do not have the concave head and they have a separate washer instead of being serrated on the edge.
If you are looking for an exact match then used is all I know of.
Old Feb 22, 2019 | 02:46 PM
Krugerand's Avatar
Krugerand
Thank you. That is what I've found. 1948-56 trucks used 42868-S8 (U-22). This is the same size with an attached external tooth washer. Fit/function is the same but does not look as good installed.
Scott Drake sell it for Mustang parts.
Old Feb 23, 2019 | 09:05 AM
resonateur's Avatar
resonateur
If you use them or source them without the lockwasher, they will sit more flush. If you’re concerned about them coming loose just add a little loc-tite.
Old Feb 23, 2019 | 09:34 AM
gatorjaws's Avatar
gatorjaws
or you can just go to a local "u pull it" salvage yard. some of those door pieces are not reproduced
Old Feb 28, 2019 | 02:18 PM
Krugerand's Avatar
Krugerand
Thanks. That might be the best choice using 356782-S.
Old Mar 1, 2019 | 08:43 PM
fivestarmmd's Avatar
fivestarmmd
How many are you looking for? email fivestarmmd@Hotmail.com
llcwhit
1947 and Older Ford Trucks
Nov 11, 2018 07:35 AM
Gicknordon
16
Jul 12, 2017 06:50 PM
ct50f1
May 3, 2017 06:28 PM
Gary E
19
Nov 17, 2015 11:11 AM
Glockem45
Nov 12, 2008 08:28 PM
