am I getting the truth
had a wheel alignment done,and they couldn't get the steering wheel straight, after the young fellow played with it for about an hour, I left and it still wasn't right.so the next day I went back and a different person did the alignment and straightened the steering wheel, but I noticed the the drivers wheel is slightly tilted inward at the top, so back I go, he said that in order for my truck to go down the road straight thats how it aligned, they put 1 3/4 camber sleeves in, he said that in order to change the camber the sleeves have to move 1/4" turn at a time and that it would tilt out ward if he moved it one notch. sorry for the long post. is this guy stringing me along?
Sounds the same to me, guy doesn't want to work on the truck anymore. All of the camber sleeves I've seen are set in degrees of offset but are infinately adjustable, meaning they do not have to be turned a 1/4 at a time. You may get some neg. camber from spring sag but this should be able to be adjusted out with the right sleeves.
omni - I had the same thing happen to me. A well respected alignment shop that had done my vehicles for years started doing sub-standard work and said it was the best that they could do. I took it another shop that was able to correct the errors and give me a printout on how far off the alignments were. Got my money back from the orginial shop and have never been back since. Good luck to you!!!
I would really find a shop that works on 4x4s and take it to them. I have had this problem with my 92 f-250 4x4. The shop I had do all of my sedans, was not setup to deal with a big truck. I finally took it to a 4x4 shop and a hour later the truck was right. they know the problems 4x4s have with alinements and can fix it right the first time. that is just my 2-cents.
V/R
John
V/R
John
