interior light
Old Sep 30, 2003 | 09:25 AM
tasdad's Avatar
tasdad
interior light
Can anyone help me with troubleshooting the problem of the interior light not working? The bulb is new and the connection seems good. Does it go on when you turn the light **** to the left as far as can go (a click is felt)? Thanks again!
Havin' fun with '65 custom cab!
Old Sep 30, 2003 | 10:23 AM
William's Avatar
William
Yes! Check for a good ground.
Old Sep 30, 2003 | 10:29 AM
MCHinson's Avatar
MCHinson
I would add that with a simple check via a Volt meter, you could figure out if your switch was actually working or not. It has to either be no voltage from the switch, or else no ground as William suggested, if the bulb is good and the socket is making good contact with the bulb's contacts. I am glad to finally see a question that I know how to answer .
