Sponsored by: Real Truck
Stick anyone?
Old Feb 20, 2019 | 02:19 PM
QUINCE's Avatar
QUINCE
Stick anyone?
Stick 2007, 6L F350, have 110k miles. Wondering if I should start saving for a clutch disc replacement. Only towed a 9000 lb RV 3-4000 miles, rest was just commuting, and I don't race the truck. Anybody has any statistics or personal experience with 6l clutch life?
Thank you
Old Feb 20, 2019 | 05:15 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Should still be good for a while. Sounds like you've treated it right. Only other thing I'd wonder if if you're the type to rest your foot on the clutch pedal when not using it then the throwout bearing might be a bit tired.
Old Feb 21, 2019 | 07:10 PM
phillips91's Avatar
phillips91
It depends on if your commuting is stop and go city driving or longer trips on the interstate. I would be surprised if it was close to worn out at 100k miles, but it all just depends on how you drive it. I would treat it like you do brakes though. When one part is worn out the others usually aren’t far behind. Change pads, rotors and calipers all at the same time so you only have to do the job once and they are all matched to each other. I’m usually dealing with semis, but when I do a clutch I resurface the flywheel, change all bearings, rear main seal, etc. I would be saving up anyways. Not because it’s about to go out, but because it’s always good to have a savings account built up if you have a truck.
Old Feb 21, 2019 | 07:25 PM
ford390gashog's Avatar
ford390gashog
My old 05 went 220k on the stock clutch before the TOB killed it. I don't use the clutch much and mainly float gears so that added to the clutch life.
Old Feb 22, 2019 | 05:31 AM
Chuck's First Ford's Avatar
Chuck's First Ford
clutch life is dependent on operator style of clutching....
just like brakes...
stop and go.. is more difficult on the clutch.. just like brakes...
rpm matching extends clutch miles...
54 years .. with a stick...
Old Feb 22, 2019 | 06:17 AM
QUINCE's Avatar
QUINCE
Thank you everybody. My commuting was 20 miles on country roads, 2-3 stops. Anybody done this lately to give me a hint on the cost? Drove stick 48 years, sold my Honda at 180k with original clutch and is still running 5 years later. The only one I paid for was a VW I bought used and change clutch at 95k in Canada. Cost me about C$1000 with water pump almost 30 years ago.
Old Feb 22, 2019 | 08:31 AM
phillips91's Avatar
phillips91
I just did a google search for clutch kits(disc, pressure plate, flywheel and alignment tool) for the zf6 and most of what I’m seeing is between about $300 to $1,000 depending on the brand.
Old Feb 22, 2019 | 08:59 AM
QUINCE's Avatar
QUINCE
Thank you Phillips91. I am not concerned about parts, more about labor. Never consider it, but can it be done on your driveway, or can I trust some mechanic that is not "diesel" rated?
kelwar
Feb 13, 2010 09:09 PM
whiteyfordzx5
15
Jun 28, 2007 10:58 AM
QwkTrip
Jun 13, 2007 01:17 PM
jman724
1983 - 2012 Ranger & B-Series
Jan 14, 2006 05:00 PM
Tool_41
Apr 13, 2003 02:24 PM
