Fuel pump not running
Old Feb 16, 2019 | 05:45 PM
Nitro1168's Avatar
Nitro1168
i have a 07 e150 4.6, won’t start not getting gas. Checked fuses,relay,button in kick panel,replaced crank sensor and fuel pump. Got a code p0191(fuel rail sensor) so it seems it could be rail sensor or fuel driver module. Pump is not running they are both $100 any body with advice I would appreciate it. I just through $300 away on a fuel pump.
Eric,
Old Feb 16, 2019 | 08:20 PM
wirelessengineer's Avatar
wirelessengineer
Eric,
Step 1. Stop firing the parts cannon. It wastes time and money.
Step 2. Follow the code. You have a code for a fuel rail sensor, so test it.
Old Feb 16, 2019 | 09:31 PM
Nitro1168's Avatar
Nitro1168
Thank you I will, I didn’t have a scanner until today so after I got the code I went online and there was post leaning both ways. I don’t know how to test it.
Old Feb 17, 2019 | 06:33 AM
wirelessengineer
Take a look at my first post. See where it says, "test it."? See how it's underlined, and a different color? That means it's a hyperlink. Click on it.
Old Feb 17, 2019 | 07:58 AM
projectSHO89's Avatar
projectSHO89
A P0191 can only be set while the engine is running. The P0191 code is probably a result of the original failure of the operation of the fuel pump (unless the battery was disconnected or the PCM was reset). If the fuel pump doesn't run, of course the pressure at the rail is going to be out of limits.
Diagnose the "no fuel pump" problem first. That means analyzing the WHOLE pump activation system to determine where the breakdown occurs. That does NOT mean firing the "parts cannon" and wasting more money and time, it means evaluating the function of the SYSTEM from beginning to end and seeing where it fails.
Old Feb 17, 2019 | 03:56 PM
Nitro1168's Avatar
Nitro1168
It was the driver module. At first it still wouldn’t start and I’m like not again, so it must take a little while until the air is out of the line. Thank you for the help.
Csmatana
1983 - 2012 Ranger & B-Series
Mar 25, 2018 10:44 PM
Bumper1475
Mar 5, 2014 06:15 AM
dkeruskie
Apr 14, 2012 07:29 PM
rmharvey
Nov 8, 2005 12:03 AM
nuttree
Oct 31, 2003 12:22 PM
