bypass hose from hell
Old Feb 16, 2019 | 01:02 PM
Ron Pauly's Avatar
Ron Pauly
I keep getting a leak from the Bypass hose that goes from the water pump to the intake. I put a new hose on it. An actual heater hose, so that should be right. I think it may be coming from where the tube goes in the intake. I have considered taking it out and cleaning up the threads and putting sealer on and screwing it back in. Is it threaded? Thoughts?
Old Feb 18, 2019 | 11:20 PM
mark a.'s Avatar
mark a.
It's drove in. I'd think you would have noticed if it was rotted out when you changed the hose. It's just a piece of tubing and you have to take the pump off to change it, they are just too close together. It's a pia. Any shop can pump your rad. up with a psi tester so you can see if that is where it's coming from, only takes a few minutes. I got the last one I replaced from Summit, but I'd bet your local parts store could get one through Dorman or some other company. I put a little Honda Bond around it and in the hole. That stuff dries like cement.
Old Feb 19, 2019 | 06:32 AM
Ron Pauly's Avatar
Ron Pauly
thought so.
Thanks for the reply.
Old Feb 27, 2019 | 10:37 AM
Dunkit's Avatar
Dunkit
is honda bond another nickname for JB weld or is it an actual thing lol
Old Feb 27, 2019 | 11:58 AM
mark a.'s Avatar
mark a.
It's real. It is for sealing 2 stroke cases. You can get it off Ebay or from a Honda shop. It's the only sealer I know of that seals anything from gas to hydraulic oil.
MsKitty
Jun 19, 2021 01:51 PM
djeviltwin
28
Nov 1, 2008 09:21 PM
1993F150XL
13
Jun 18, 2008 08:24 PM
Smith76
Feb 19, 2006 09:21 AM
tmcalavy
Apr 24, 2000 09:14 AM
